Did they make a 6 lug Corp 14 with 3.43 Gears?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bigblock454, Oct 25, 2002.
  1. bigblock454
    bigblock454 Clack Clack Clack Premium Member
    Jun 18, 2002
    546
    16
    Terre Haute IN
    Looking to replace my stock 10 bolt but want to keep the ralleys. Anyone have one?
  2. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Do a search at http://www.mypartshop.com
    Applicable years are 88-98 C/K series trucks or 96-up Savana/Express. Can be a 1500 4x4 with 14-bolt cover, 2500 2wd with 6-lug wheels (narrow track), or 2500 4x4 with 6-lug wheels (wider track).
    3.42 and 3.72 are the most common ratios.
    Spring perches do need to be changed to fit the 88-older trucks.
  3. thatK30guy
    Jan 12, 2001
    32,076
    55
    The simple answer to your question is YES, and the key word to your axle search is SEMI FLOATER. /forums/images/graemlins/thumb.gif
  4. bigblock454
    Jun 18, 2002
    546
    16
    Terre Haute IN
    ok cool, i didn't realize all semi floaters were 6 lug.
  5. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    theyre not i got a 14SF 8-lug. Course its an older truck be wary of that, not all SF's are 6 lug. 88-98 light duty 3/4 tons got em, some vans too i think but not sure exactly which
  6. thatK30guy
    Jan 12, 2001
    32,076
    55
    All the 5 and 6 lugs are SF's from the factory.
    There are aftermarket kits to convert them to FF, but they are pricey.
    The 14 bolt SF is available in 5, 6 and 8 lugs. The 5 lugs is the 454SS truck rearend.
  7. 4x4Freak
    4x4Freak 1/2 ton status
    Apr 21, 2002
    792
    Lubbock, TX
    The 6 lug shafts will swap into the older 8 lug axles, correct?
  8. thatK30guy
    Jan 12, 2001
    32,076
    55
    Yes, they will, but there are 2 different lengths of the 6 lug shafts.
