Did they make HEI for straight sixes?
Discussion in 'The Garage' started by dontoe, Sep 30, 2006.
  1. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    My '74 has points.
    I'd like to put a HEI distributor in it if they were used in later models.
  2. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Yes they were supplied with HEI. 70's Novas would be a good start.:D
  3. JEBSR
    JEBSR 1/2 ton status
    Dec 23, 2004
    1,541
    Clarksville, TN
    I believe 74 is when they started using HEI so anything after that with a 6 should use it. Yes my brothers 76 nova had one.
  4. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Don, all those distributors are ~30 years old now. It might be best to get a brand new one; CRT Perf. or D.U.I. or MSD?
  5. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    Yeah.............:wink1:
    Thank's y'all!!!! :D
  6. diesel4me
    Jul 24, 2003
    17,547
    937
    Massachussetts
    I have one...
    I saved the HEI from my 79 C-10's 250 six--it had the coil in the cap,some years the sixes had it on the block ,and used a different cap,with a coil wire..
    If your interested in it,PM me,--I won't be home until tomorrow though..going to a concert in NH tonight...:crazy:
  7. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    There you go Don, mileage vs. $$.:D
  8. 3 on the tree
    3 on the tree 1/2 ton status
    Oct 16, 2004
    3,970
    gunnison colorado
    If you get a used OE one, make sure it comes with the shaft extension. The 6 cyl HEI shaft is actually a V8 shaft with an extension pinned to the end to reach the oil pump. The extension is not easy to find, took me 2 weeks and a lot of phone calls.
  9. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    I don't guess you have any pics of the extension?
    That's a good lookin clean 6 banger you have!
  10. 3 on the tree
    Oct 16, 2004
    3,970
    gunnison colorado
    Thanks, it has 79K miles on it. When I put a new head on it, with hardened seats, I cleaned it up some and threw some paint on it.
    The extension shaft is bout 3-4" long, with a slot in the top that engages the oil pump drive tang. The other end has the drive tang. Also, the top has a hole drilled thru for a shear pin.
  11. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    I've got another "three-on-the-tree" now..........been a few years!!! :D
    1974, 250-6, manual brakes, steering, trans. 65,000 original miles!!! :D
  12. 3 on the tree
    Oct 16, 2004
    3,970
    gunnison colorado
    Cool!!!!!! Don't shift from first to second too quick, or you will be in "lock up land".
  13. divorced
    Jul 20, 2004
    5,115
    While we're whippin em out and showin em off, here's my 3 on the tree behind a 250 L6
  14. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Wow, doesn't get any simpler than that, straight too(?)
  15. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    C20?
  16. divorced
    Jul 20, 2004
    5,115
    Yep, C20. It has power steering and power brakes, Eaton rear with 4.56 gears and a no-spin, 3 on the tree and a 250-6.
  17. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Thats a workin Burb.:D
  18. 3 on the tree
    Oct 16, 2004
    3,970
    gunnison colorado
    I thought the standard motor for those was the 292????
  19. divorced
    Jul 20, 2004
    5,115
    I know very little about these older trucks. The sticker under the hood says it's a 250, and the computer at the auto part store had a listing for a fuel pump for the 250. I'm not sure if it's standard or not though?
    I would rather have the 292 :D
  20. 3 on the tree
    Oct 16, 2004
    3,970
    gunnison colorado
    Which 3 speed does it have-Saginaw or Muncie. I believe the Muncie only has 4 bolts on the side cover and the Saginaw has 6 or 7. 292 side covers are about 6" tall, whereas the 250s are about 4". The 250 could be the standard motor. Everything above the 250 got an engine badge on the front fender, even the 292 had one.:D
