die cutting ? what is it exactly ??
Discussion in 'The Lounge' started by R72K5, Dec 27, 2003.
  1. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    i found a listing of a small shop or something here in town that someone must have just started because ive never heard of it and this town is not very big at all and its in the die cutting listing of the book, what exactly is die cutting ?? for what machines ? presses ? ?or ?
    humm..
    thanks
  2. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Die cutting is basicly using CNC grinding machines to produce precision parts made out of metal, plastic, ect.
    For instance: A washer produced by stamping. Stamping the washer distorts it a little but it is good enough for its uses.
    If you wanted a more persision washer with no distortion and max uniforimity it would have to be die cut using high speed grinding bits or cut by using high pressure water, or laser.
    Porting heads and intake manifolds is also a form of Die cutting. You use a high speed Die grinder to remove material and polish them
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    well thats cool then, hmm, about time we had a place like that around here, although im sure its someones backyard garage business, but heck, better than nothing /forums/images/graemlins/laugh.gif ill have to check it out sometime.
    cool
  4. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Depending on the type of shop, it could also be a 'rule'-bending type die cut.........like for a plastics company. They bend the 'rule' into whatever shape you want for you to cut out plastic, as in vacuum thermoforming, etc. /forums/images/graemlins/thumb.gif
