DIED cranked to nothing
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by DUKE, Apr 23, 2002.
  1. DUKE
    DUKE 1/2 ton status
    Nov 14, 2001
    879
    Davenport Iowa
    Events as best I can discribe;
    Truck is running great long time no problems, I run up to my appartment to get some books for class, jump back into the truck in a hurry crank her. I hear a few klicks in a row. Similar to the kind like when you keep the key turned after the engine is running. Everything is dead, jump out check the battery connections and the battery all good. still dead. go for a jump start, turn the key and the volt gauge works, turn the key just one click dead. Now she is dead and the battery is fine. WHAT WHAT WHAT. It is late and dark give me ideas for the morning. I was thinking I finaly killed the starter, but wouldnt the electronics work still? did it blow a fuse in the prosess? why would the electrics work again for a sec but then not again? HELP
  2. 77fixer
    77fixer 1/2 ton status
    Nov 22, 2001
    464
    Meridian, ID 83646
    How do you know the battery is good. I had similar problems, couldn't even jumpstart. I changed the battery with a spare, same symptoms. Turns out both batteries were bad.
  3. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    Shot in the dark but, starter's shot...
    Chris
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I've had batteries just die suddenly, for no apparent reason. But more often, I've found corrosion under the side post connector. Remove both cables and make sure that there isn't anything growing under the rubber insulation. If so, clean them up good and put 'em back on.
  5. Zepplin
    Zepplin 1/2 ton status
    Aug 29, 2000
    920
    Bay City, MI 48706
    It sounds like a heat soak problem with the solenoid. This used to happen to me all the time. I would drive it to a store or something, shut it off, and then come back out and it wouldn't start. Usually I would wait a few minutes until it cooled off and then I would hit the starter with a hammer. It would usually get me to the parts store for a new starter.
    I would get a Furd remote solenoid or buy one from Summit for around $25. Mount it on the inner fender and call it good.
    My 2 sense.
