Diesel Additive
Discussion in '1982-Present GM Diesel' started by cegusman, Jul 11, 2001.
  1. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    What is a good diesel additive that some of you fellow K5ers use.
  2. OFFRDK5
    Oct 2, 2000
    1,881
    Central IL
    Stanadyne
    Best I have seen and used. Its expensive, but it does its job.
    SK-15
    J**P...it's whats for dinner!
    Roads? Where we're going, we don't need any roads!
  3. chevy4x4
    chevy4x4 1/2 ton status
    Apr 27, 2000
    1,454
    How expensive is it, and how much do you use?
    <font color=purple>L8R...</font color=purple>
    <font color=green>chevy4x4
    </font color=green>
  4. OFFRDK5
    Oct 2, 2000
    1,881
    Central IL
    Pricing varies, I think I paid $20 for 1/2 gal.
    I started with a "One Shot" from them and saw how much it used and just kept refilling it from the bigger container becasue it was very close to my tank size of 31 gallons. Your useage may vary.
    <A target="_blank" HREF=http://www.stanadyne.com>http://www.stanadyne.com</A>
    Go there and find a dealer in your area and call for pricing and more info.
    SK-15
  5. chevy4x4
    Apr 27, 2000
    1,454
    How often do you use it?
    </font color=green>
  6. OFFRDK5
    Oct 2, 2000
    1,881
    Central IL
    I use it about every other tank, but thats becuse I don't have a fuel guage and fill up to make sure I don't run out of fuel. If you knew how much you have in your tank you can figure it out. My little "One Shot" was for 30 gallons. I have a 30 gallon tank and I fill up about half way so I only needed it every other time. You can do it more or less. Just need to play with it and find your mixture!!
    Laters
    SK-15
  7. childs
    childs Registered Member
    Mar 15, 2001
    19
    delaware usa
    It is the best and not that much per tank. They also make John Deere's for them.
    DE k5
  8. desertrat67
    desertrat67 Hawk Driver
    Jul 5, 2001
    3,982
    74
    Dumfries, VA
    Have you ever used Marvel Mystery oil? I used it for 14 years on a little isuzu diesel and it helped get rid of the black somke and keep my mileage at 35 for the life of the vehicle.
  9. OFFRDK5
    Oct 2, 2000
    1,881
    Central IL
    desertrat67: No...I have never tried that stuff. Was the stuff rated for Diesels? Was it the stuff that went in the fuel or the oil?
    SK-15
  10. Double_T
    Double_T Registered Member
    Jun 28, 2001
    71
    Orygun
    Stanadyne has the best reviews. Marvel MO works great too. So does a qt of tranny fluid every once in awhile. The problem with Marvel and tranny fluid is that it turns your fuel red which is the color of "off highway use only" fuel (according to the EPA). Buy Stanadynes Performance stuff.
  11. desertrat67
    Jul 5, 2001
    3,982
    74
    Dumfries, VA
    It works pretty good. you can put it in your fuel and oil with every change. I used it for years in an 82 isuzu P'UP with a 2.2L engine that would smoke like hell after 3000 miles, but do an oil change and add the Marvel and it would run clean for about 1500 then slowly start up again. My Granpa was a trucker for about 40 years and used it in every tank.
  12. Oilman
    Oilman Newbie
    Aug 6, 2001
    3
    The best diesel additive is the one from LE called DCI+. It has everything that a diesel additive should have.
    lubricity additive
    diesel combustion improver
    an ashless detergent dispersant
    an oxidation inhbitor
    a pour point depressant
    rust and oxidation inhibitors
    metal deactivators
    and it has been proven to improve fuel mialage by an average of 7.4% in a 5 fleet 113 truck test.
    In the past year I have investigated 8 additives and written 5 articles on which one was the best. The LE DCI+ came out on top and seems to do everything in one additive. Some additives work well but only do one thing like lubricate or have a Cetane improver, but the LE DCI+ is the only one that does it all. The company that sells it is Mag-Hytec at 1-818-786-8325
    The price is just over $7.00 per pint and it treats 125 gallons or about 4 oz for a 32 gallon fillup.
    Good luck and I hope I've helped.
  13. OFFRDK5
    Oct 2, 2000
    1,881
    Central IL
    [censored]! You seem to know alot about additives as well as oil!!!
    SK-15
