Diesel fuel delivery question....
Discussion in 'The Garage' started by stallion85, Jul 29, 2006.
  1. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    This may seem like a retarded question to some of you, but does my 379 Deisel have a mechanical fuel pump like a 350? And what would if any problems would I have using a fuel cell with my engine?
  2. diesel4me
    Jul 24, 2003
    17,547
    937
    Massachussetts
    yup...
    The 6.2 (aka 379 cid!) has a "Lift Pump" on the engine block ,similar to a small or big block gas motor..it delivers the diesel to the injector pump..
    I have never used a fuel cell with a diesel,but I don't see why you couldn't..a stock diesel tank has water drain provisions though,and a return line is needed as well,but those issues can be worked around..maybe some company makes diesel specific fuel cells?...I'd think marine applications would be available,since many boats use diesels..:crazy:
  3. miniwally
    miniwally 1/2 ton status Premium Member
    Aug 11, 2003
    3,065
    Colorado
    It will have a lift pump.
    If you are haveing problems with it install a inline electric pump as your new lift pump and by pass the stock setup.
    You can use any fuel cell. Jegs makes a few that have a supply line in a corner, a vent and a return. Look at those if you are buying a new one.
    If you are retrofitting your existing cell then get a bulkhead fitting from jegs or someplace like them and install it in side of the cell real low.
    I will PM you my # so I can explain this better.
  4. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    Thanks Brandon, I will give you a call. And this will be using my exisiting 22 Gal JAZ Fuel Cell.
