Diesel fuel economy & swap advice
Discussion in '1982-Present GM Diesel' started by C5K5, Jun 8, 2002.
  1. C5K5
    C5K5 Registered Member
    Dec 18, 2001
    8
    Colo Springs, CO
    What sort of fuel economy do you get with the 6.2 and 6.5? I have an 86 Blazer with a 307 gas (12 mpg hwy) and I'm wondering if I can do better either through adding fuel injection or swapping a diesel in. Also, wanting to keep my np205 and 700r4 since I've already invested in their rebuild. Any ideas? What about non-GM diesels like Cummins?
    Thanks-
    Adam
  2. Oblin Goblin
    Oblin Goblin 1/2 ton status
    Apr 30, 2000
    205
    Davis, CA
    I get 16-18 mpg with my Blazer. I've heard of people getting better than 20 mpg with these engines but I never have. I probly could if I drove slower than 70 on the freeway though /forums/images/icons/smile.gif As far as keeping your 700r4, you probly could as long as you got a non turbo 6.2. I don't think it would hold up very well behind a turbo diesel though. A cummins diesel would be cool but it would be quite a project. You might consider a 3.9L cummins. It would be alot easier to fit though might be a little under powered. A turbo 3.9L cummins will make more power than an NA 6.2 but not as much as a turbo 6.2. In any case swaping in any diesel would be pretty complicated. Theres alot more to it than just swaping in the engine.
  3. René
    René 1/2 ton status
    Mar 14, 2002
    208
    Michelbach, Germany
    between 13,8 and 15,8 mpg.
    In my opinion is worthwhile itself a diesel engine then only if you are looking for an undemanding mule, or diesel fuel is clearly cheaper than gasoline.
  4. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    I guarantee that you'll be able to almost double your highway mileage with a diesel in your K5, as long as you keep your top speed below 60 MPH and keep you motor well maintained.
    In my 1/2 ton 2WD I can get 28 MPG on long trips, so there's no reason that a heavier 4x4 couldn't get 20-22. What gears are you running?
    I have a 700r4 behind my 6.2. It's done a lot of towing and is still working fine. Once again, regular maintenance is the key to the longevity of a 700r4
  5. calcide
    calcide 1/2 ton status
    Dec 21, 2001
    283
    I get 16 MPG all the time. On the highway, in the city, with my 37s and with my 31s (I've got 4.10 gears). I didn't get my diesel for the mileage (although that helps), I got it because it has mechanical fuel injection. No computer, O2 sensor, TPS, MAF/MAP sensor, etc.
    The diesel will run better at severe angles than a carb gas motor, without all the CRAP in electronic fuel injection.
  6. C5K5
    Dec 18, 2001
    8
    Colo Springs, CO
    Thanks to all for your replies. Haven't really decided yet, but you've given me stuff to think about. I think I'll have a hard time plunking down the dough (and complications) for a different engine if that only buys me (according to most of you) 4-6 mpg, and more only if I make some serious changes in my driving-- no way I'll be keeping it below 60 on the highway, that's for sure! Don't know what gears I have, but it seems pretty spry on 35s.
    thanks again-
    adam
  7. OFFRDK5
    Oct 2, 2000
    1,881
    Central IL
    You might want to consider instead of swapping in a new engine buying a whle new rig. With all that you have to change it might be easier. /forums/images/icons/cool.gif
  8. Batmanjr
    Batmanjr 1/2 ton status
    Mar 23, 2001
    1,537
    Copperas Cove, Texas
    My 83 came with a 700 behind the 6.2L and it works more reliably than my Honda! I have 31" tires and 3:73 gears and the truck gets 22+ mpg on the freeway and about 18 in town. I'm 22 and no slow go'er so that should tell you something about a diesel. Mine is currently a non turbo, but with a little work and some time, it soon to be! /forums/images/icons/cool.gif
