Diesel Fuel Pump
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ReIN4st, Jan 14, 2001.
  1. ReIN4st
    ReIN4st Registered Member
    Jan 1, 2001
    32
    SanJose,CA
    I have an '82 6.2 Blazer with a bad mech. fuel pump. Can I use a small inline electric fuel pump in this vehicle ?? I have one laying around, its about a 4psi I beleive. Thanks John
  2. JimmyDie6.2
    JimmyDie6.2 1/2 ton status
    Jun 20, 2000
    453
    Long Island
    I don't know a definitive answer to your question, but consider this. you will need to use a block off plate where the mechanical pump goes, Is it the same as a small block, so you could just use an SBCs? Is a block off plate even made if not an SBCs? Can you make one? the pump is on an angle if I remember correctly and is bigger than on an SBC. you will need a regulator. I believe the mechanical pump only delivers the fuel to the electic pump on the intake at a very low PSI, then the electric gives the injectors the proper PSI. I would think that if you had the regulator for your added electic pump calibrated perfectly, you could get away with it. but for 20 bucks for a new mechanical pump, maybe just replacing it would be best.........js
  3. ReIN4st
    Jan 1, 2001
    32
    SanJose,CA
    Oh the pump on the intake is an eletric, I thought it was mechanically driven also. Anyway I'll give a new mech. on the block a shot. Thanks for the information
  4. JimmyDie6.2
    Jun 20, 2000
    453
    Long Island
    not only is the pump on the intake electric, but it is really freakin expensive.....................js
  5. OFFRDK5
    Oct 2, 2000
    1,881
    Central IL
    <A target="_blank" HREF=http://www.thedieselpage.com>http://www.thedieselpage.com</A>
    SK-15
    J**P...it's whats for dinner!
    <A target="_blank" HREF=http://SK-15.coloradok5.com>http://SK-15.coloradok5.com</A>
    Roads? Where we're going, we don't need any roads!
  6. Gopherkiller
    Gopherkiller 1/2 ton status
    Aug 14, 2000
    188
    I, would get rid of the mech fuel pump. You can buy the plate from Chevy. Oneday, buy yourself a good inline electric pump, you won't have any complants. It helps when you change filters, or run out of fuel! GOPHERKILLER
