Diesel Fuel... sock?
Discussion in 'The Garage' started by Pookster, Jun 6, 2005.
  1. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Do the diesel's in our trucks have an in tank sock filter? We dont have a fuel pump in tank so it would seem kinda silly to have one, but I have heard conflicting information, with no real answer....
  2. Iron_Weasel
    Iron_Weasel Registered Member
    Mar 29, 2005
    70
    New Mexico
    I checked a diesel Blazer manual at random, so I got info off an 85 since you didn't specify a year. Anyway, from the digrams and information, there is no in tank filter...just the normal fuel filter/water seperator.
  3. Pookster
    Nov 21, 2000
    3,195
    NYC, NY, USA
    thanks dude. :)
  4. dyeager535
    26,976
    At least in the gas applications, it doesn't matter if theres an in-tank pump or not. There are two functions of the sock: prevent crud from reaching the fuel pump (electric or not) and to prevent water from getting to the engine.
    Perhaps diesel can get too "thick" to get through a sock filter, and with a water seperator already, no reason for that in the tank.
  5. Diesel Dan
    Diesel Dan 1/2 ton status
    Feb 27, 2002
    798
    Warren, Ohio
    One of the main reasons for the "sock" is for fuel pickup. It acts like a candle wic. Only one spot of the sock needs to be in fuel and it will draw in fuel. That's how they can basically suck the tank dry when if all it had was an open end pipe it would leave quite a bit of fuel in the tank.
    And yes, it should have one. It is not called a filter, IIRC GM calls it a strainer.
  6. dyeager535
    26,976
    I lied.
    Second page part #12 of the fuel tank diagrams/parts listing.
    parts manual
  7. Pookster
    Nov 21, 2000
    3,195
    NYC, NY, USA
    crapola. Ok, so, any ideas as to how often this sock needs to be replaced? Seems kinda pointless in a diesel application, as that "wicking" action would sitll introduce air into the system and cause the engine to stall. Not to mention all the usual crud that gets into diesel fuel that it needs good filtration.
  8. dyeager535
    26,976
    I'd say that sock needs replaced about once every 15-20 years.
    *IF* they are bad it seems that its because they have rubbed the bottom of the tank too long, and get a hole worn in them. Also, if the tank is in poor condition, the sock can get plugged up with crud, which in some extreme cases hurts performance.
    The Delco electric fuel pumps that I bought all came with a sock, so GM seems to think that fuel pump replacement is about the interval the sock should be replaced. Since the fuel pumps seem to typically last 100,000 miles+, that's a pretty big interval.
  9. grape
    grape Registered Member
    Mar 10, 2005
    27
    texas
    my 82 diesel k5 has a sock and i put the original one back in with the sender and fuel pickup after i restored everything, hell the tank was spotless inside as well, which surprised me after 23 years.
