diesel help please
Discussion in 'The Garage' started by KGsK5, Feb 14, 2007.
  1. KGsK5
    KGsK5 1/2 ton status
    Aug 26, 2006
    343
    Havre de Grace, Maryland
    went out for a little field runnin at one of my friends house today. hit a couple small mud holes and did some donuts in the new snow.
    as i was coming through a mud hole, the truck stopped. just shut down. hit the starter, nothing. it was mainly just muddy water with some ice in it. wasnt even high enough to get halfway up my 33s.
    so i had my buddy yank me out. first i thought i might have run out of feul somehow :doah: dummy me has not working fuel guage. so i had it towed back to his shop so i could bleed the lines. well we got it back and found that i did have feul. could hear it sloshing in the tank.
    it still will not start and i have no idea what to do with it. the starter will crank and crank and get nothing. not even a try.
    i even hit it with some ether... i know... its a diesel and your not suposed to use it. but it wouldnt even fire with that.
    any ideas on what to check? im totally at a loss here.
    thanks
  2. sledheadak
    sledheadak 1/2 ton status GMOTM Winner
    Apr 29, 2005
    1,283
    anchorage,alaska
    check the power wire going to the injector pump to make sure it didnt fall off.also check the wired leading to the starter the ice might of broke one.
  3. KGsK5
    Aug 26, 2006
    343
    where is the feul pump located on the diesels? or does it even have one? is there any way to test to be sure that the IP is working?
  4. ssped
    ssped 1/2 ton status GMOTM Winner
    Jan 5, 2006
    1,529
    Mission Viejo
    in the front under the intake manifold. There is large pink wire attached to the injector pump. check for voltage there and make sure it is conected. check for fuel flow by cracking the injector line. careful it is under pressure.
  5. KGsK5
    Aug 26, 2006
    343
    which injector line should i crack? at the injector? at the ip? i cracked the top one on the ip and got nothing. didnt take it all of the way off though.
    from what i see when i look at the ip, there are 8 lines in a circle and one in the middle. the one in the middle is the supply from the tank, correct?
    i did pull off the feed to my fuel water separator located on the firewall... dry. no diesel at all.
    now that im not so frustrated, im starting to think that i did somehow run out of fuel...
  6. ssped
    Jan 5, 2006
    1,529
    Mission Viejo
    Well 1st check for power but sounds like you have a crack a line and are sucking air. any air in the system and she will not run. check the rubber hoses back to the fuel tank. you can bleed air from the lines at the rear of the intake manifold. it is a pretty simple system but any air leaks will take it out.
