Diesel Jimmy?? how are they
Discussion in 'The Garage' started by Disciples Performance, Jun 6, 2006.
  1. Disciples Performance
    Disciples Performance 1/2 ton status
    Dec 6, 2005
    404
    Kelowna BC, Canada
    hey guys my friend is lookin a buying a 1986 Full Size Jimmy 4x4 now its got the 6.2 diesel in it now how are those engines gutt less? or what its just stock right now but he would more then likely swap 3/4 suspension and what not into it so just let me know thanx
    Nick:D
  2. 1-tonmudder
    1-tonmudder 1/2 ton status
    Apr 24, 2005
    3,052
    In a junkyard somewhere
    They are a commuter engine,not intended for any real work(at least not any I seen).If you are wanting it to pull much of a trailer with you are wasting your time.I have seen them with a 700R4 and 308 gears before.
  3. Disciples Performance
    Dec 6, 2005
    404
    Kelowna BC, Canada
    well this one would not really be bagged on he doesnt really know how to 4x4 lol but he wants something to go camping in so would it be an alright platform for that?
  4. 1-tonmudder
    Apr 24, 2005
    3,052
    yeah it should be fine for that.A diesel motor is as good as or better than a FI gas motor for dependability as they are almost all mechanical and not very electrical like a FI motor.
  5. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,925
    337
    Fort McMurray, Alberta
    As mentioned, they can be awesome for a daily driver. They get good milage, and many people compare the acceleration to be similar to that of a mid 80's stock 350.
    Definitely not for a race car, nor is it designed to be towing large loads. Its a light duty commuter type engine.
  6. RootBreaker
    Nov 29, 2001
    5,118
    173
    Williamstown, NJ USA
    I was going to convert mine to the 6.2 turbo diesel until I saw the numbers.. then figured alot of $$$$$ to get it moving...
    estimated numbers as I dont remember exacts...
    non turbo
    135hp/295lb ft torque
    turbo'd
    155hp/320lb ft torque
    that was enough for me to change my mind.... :crazy:
  7. grimjaw
    grimjaw 1/2 ton status
    Jun 19, 2004
    944
    Seymour, TN
    GM states for the 85-88 6.2L 155HP and 250TQ. The Banks Sidewinder Turbo kits adds +60 hp and +115 lb-ft torque. Then there is turning up the IP and/or propane injection.
    Stock they leave you wanting.
  8. NYDIESELDAVE
    NYDIESELDAVE 1/2 ton status
    Aug 6, 2005
    166
    Penfield, NY
    Well, I have a 6.2 in my Jimmy and this is what I would say. The truck is not really made to haul heavy loads, nor does it have alot of power stock. With that said, I get awsome mileage, super reliable, great on inclines, pretty simple engine. I like the compact package of the Jimmy which is nice and you can tune the engine to make some realy nice power. You can also pretty much direct swap in a 6.5 NA. Just need to make a few changes.
  9. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    just for the record, i've seen dyno specs on an old tired 6.2 w/ a turbo putting out 200hp and 500lbs tq. i really dig my 6.2 - doesn't feel gutless, but definitely not a racecar. i suppose my sig gives away my bias.
  10. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    Those numbers are pretty far off...
    Peterson's did a Banks kit on a 6.2 with several chassis dyno pulls along the way. After having the injectors rebuilt as well as the injector pump, adding a 'J' code intake and decent exhaust it put down 135 hp and 340 lbs of torque to the rear wheels. With the turbo it put down 172 hp and 451 lbs of torque at the rear wheels.
    The 6.2's biggest downfall IMO hasn't got anything to do with the motor at all. It's the horrible factory gearing...with decent gears they get up and get moving just fine.
    Rene
  11. NYDIESELDAVE
    Aug 6, 2005
    166
    Penfield, NY
    I agree gearing plays a huge part. I changed mine and I felt like I had rebuild the engine also. It had alot more get up and go. Also, running good fuel will make a big difference. If you can get off-road diesel fuel; you can definintely feel a difference IMO. Just don't get caught doing it.
  12. dyeager535
    26,980
    The ones I've driven (all TH400's) I noticed that even with the crummy 3.08 gearing, the transmission shifts way too soon. I'm not sure if all the 6.2 trucks with autos were this way or not, but I found that it felt much better acceleration-wise manually shifting it a bit later than stock. The difference was actually night and day to me. Not that it was a screamer either way, just got it moving a lot better.
    Of course, with a manual, this would be much less of an issue. :)
  13. steve_kibbe
    steve_kibbe 1/2 ton status
    Feb 4, 2004
    2,895
    Spartanburg, SC
    You can adjust when the tranny shifts:D
    I had a 83 3/4 diesel with a 4 speed, 33" tires, and 4.10 gears, it wasn't fast, but I could get it moving pretty quick. I also had the chance to drive a cucv with 4.56's and 30-31" tires, it accelerates pretty quick, but you're wide open at 55mph:D
    My truck averaged 17 mpg, and driving the cucv for 560 miles @ 55mph, I got 17 mpg aswell, and it has a flat bed on it.
    I wish my 88 blazer had a 6.2 in it with the 700r4. If it had 3.08's or 3.42's, I'd swap them out for 4.10's and still get 20mpg.
  14. grimjaw
    Jun 19, 2004
    944
    Seymour, TN
    Thats good to know...:D. An OD trany and 37" tires will fix that.
