diesel K5 running hot?
Discussion in 'The Garage' started by KGsK5, Aug 28, 2006.
  1. KGsK5
    KGsK5 1/2 ton status
    Aug 26, 2006
    343
    Havre de Grace, Maryland
    my 6.2 in my 83 blazer seems to be running hot. the temp guage on the dash is reading 220 after it warms up and runs for a bit. is this too hot?:confused: i dont no much about diesels so any input on this one would be greatly appreciated.
  2. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    Is there bubbles running back into the overflow resevoir after running it for a little while? 220 is a bit too hot for a diesel, may have a head gasket leak or cracked block that rears its ugly head after starting.
    could be a bad guage though, try running it from cold with no rad cap on at idle and see if it gets hot
  3. tRustyK5
    Jul 23, 2000
    36,169
    1,372
    E-town baby!
    At idle a 6.2 should have trouble getting warm enough to open the thermostat. They really don't warm up until they work a bit. If it's getting that hot at idle I'd be taking a much closer look at everything to find the problem.
    Rene
  4. KGsK5
    Aug 26, 2006
    343
    should i start by flushing the radiator? or do you think its more involved then that?
  5. BowtieBlazer
    Jul 15, 2001
    2,462
    thats a good start
  6. diesel4me
    Jul 24, 2003
    17,543
    936
    Massachussetts
    but first!..
    Remove the thermostat before flushing ,for best resuls..I'd ditch it and get a new one,whatever temp the 6.2 came with originally (sorry,I'm not sure what temp is correct for a diesel--gas motors use 195 degrees,but I've never had to change my 6.2's thermostst yet!)...if flushing doesn't help,it could be a head gasket or leak in the block,or a clogged radiator that isn't flowing enough coolant..or a defective water pump impeller,collapsed hoses,etc..
    I'd check with an accurate gauge before doing anything..the dash gauges are not known for great accuracy!..if its not peuking coolant out of the overflow,its probably not overheating...:crazy:
  7. tRustyK5
    Jul 23, 2000
    36,169
    1,372
    E-town baby!
    X2
    My factory guages were so far off I might as well have had idiot lights instead...
    Rene
