Diesel lift pump Question???
Discussion in 'The Garage' started by ryanstrucking, Jun 14, 2004.
  1. ryanstrucking
    ryanstrucking 1/2 ton status GMOTM Winner
    Feb 2, 2003
    182
    Calgary AB Canada
    I've got a 94 chevy with a 6.5L TD
    My question is: with the key in the run postion what if any should be the voltage to the fuel pump on the frame
    (pre injector pump)?
    Any help or input would be much apreciated.
  2. ryanstrucking
    Feb 2, 2003
    182
    Calgary AB Canada
    Ok.
    Heres where I'm @.
    Checked the voltage at the lift pump with the key on and the engine off and i'm getting 0 volts.
    Checked the in line fuse on the fire wall and its good except its not getting power there either.
    Any suggestions as to what else to look for???
