diesel oil change question-filler tube location-i sound dumb
Discussion in 'The Garage' started by rwright07, Feb 11, 2007.
  1. rwright07
    rwright07 1/2 ton status
    Jul 30, 2005
    536
    corporate hobo
    oook so i bought a diesel a few months ago and need to change my oil now... i have everything and am ready to drain but im not sure where to add oil to... i know there is a filler tube, but am not sure where-haha
    help me out so next time i wont look so retarded.
  2. ssped
    ssped 1/2 ton status GMOTM Winner
    Jan 5, 2006
    1,529
    Mission Viejo
    in front of the air cleaner over the water pump.
  3. rwright07
    Jul 30, 2005
    536
    corporate hobo
    whats it look like? just to the left of the IP electronics
  4. DEMON44
    DEMON44 Low-Tech Redneck
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
    Diesels usually fill into a valve cover OR gearcover. I've never had a chev diesel, but its a cap....round, about 2"-3" diameter.
  5. rwright07
    Jul 30, 2005
    536
    corporate hobo
    theres no breather hole on the valve cover and idk what the gearcover is
    help me out guys?
  6. DEMON44
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
    Front........ middle.......... directly above water pump.....round black.....yellow writing..........probably has an oil can logo
  7. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,923
    333
    Fort McMurray, Alberta
    This is a 6.5L, but the oil fill is in the same place on a 6.2L
  8. DEMON44
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
    dang can't get my pic to show.........but its looks like that one. Caps may be different or the same.
  9. ssped
    Jan 5, 2006
    1,529
    Mission Viejo
    Yep looks like what he said!
  10. Russell
    Jun 23, 2000
    7,923
    333
    Gotta use the [|IMG] tags, less the |
  11. DEMON44
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
    BAM........there it is. thats where it starts and ends.
  12. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    REPOST!! :haha: both pics worked for me. :)
  13. BKinzey
    BKinzey 1/2 ton status
    Jan 13, 2006
    3,145
    Hollywierd, CA
    WOW Colby, that's one purddy Ma-cheane. And the filler tube is quite.....um... Festive... and... Gay. :p: Yes Festive & Gay:p::p:
  14. DEMON44
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
    I gather you didn't follow the progression of things very closely here :rolleyes:.................
  15. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    hmmmm. i'm confused.
  16. BKinzey
    Jan 13, 2006
    3,145
    Hollywierd, CA
    My Goodness me! Wrong credit! It's Demon44's. Such a shocking color I was temporarily blinded!
    Is it a 6.2 or 6.5? If it's a 6.5 with a manual IP do you have an optical sensor on the timing gear cover? I'm building a 6.5, manual IP and trying to figure out how to hook up a tach. Thought maybe the optical sensor would give me a signal I could use.:confused:
    Your build is a lot cleaner than mine:bow::bow:
  17. BKinzey
    Jan 13, 2006
    3,145
    Hollywierd, CA
    Certainly understandable if you had a pink Oil fill tube:D
  18. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    nope, i have a slightly pink oil dispenser. :haha:
    ok, sorry, that was inappropriate. :(
  19. DEMON44
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
    that was awesome :haha:
    ..........but it wasn't my engine. I've never had a GM diesel, only owned B cummins'
    ...........I found the pic online...........she picked the filler color :D
  20. BKinzey
    Jan 13, 2006
    3,145
    Hollywierd, CA
    That's ok, the new pic shows enough of the cover I can see there isn't an optical sensor so I got my answer anyway:D
    Colby if your pink dispenser is discharging anything with the consistancy of oil get yourself to a doctor! Emergency Room if it looks like used oil!
    End of Hijack!
