Diesel radiator -- coolant level sensor
Discussion in 'The Garage' started by dremu, Jan 22, 2007.
  1. dremu
    Feb 27, 2000
    15,954
    445
    East of San Francisco
    Hard to tell in the dark, but I assume that the coolant level sensor is supposed to thread into a pipe-lookin' thing that sticks out of the radiator ... and said pipe should not turn, right? :doah:
    The sensor is all gunked up, it's been leaking ... figgered I'd take it out, wire brush it, and put it back in ... but now the entire assembly, i.e. the sensor and the little stub it's on, are turning. :(
    I suppose one could rebraze the thing back onto the radiator... but I suspect it's new radiator time.
    Any input?
    -- A
  2. BKinzey
    BKinzey 1/2 ton status
    Jan 13, 2006
    3,145
    Hollywierd, CA
    Yes. I didn't know they were 2 pieces. Hows the rest of the radiator look? As expensive as they are I'd definately give brazing another look.
  3. dremu
    Feb 27, 2000
    15,954
    445
    Didn't know what were two pieces?
    Honestly, I'm a bit scurred of the goo in the radiator, so if I'm gonna pull it out to braze it, I should take it to a shop for cleaning, at which point the hassle and downtime plus the cost is getting me closer to a new radiator. Though, as you say, they are NOT as cheap as the ones for the gassers!
    -- A
  4. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,922
    333
    Fort McMurray, Alberta
    My K5 is an ex-diesel rig, and the low coolant light is on all the time. How does that sensor work? I wouldn't mind hooking it back up, and actually using it...
  5. dremu
    Feb 27, 2000
    15,954
    445
    It's the same sensor as used on some windshield wiper systems ... I assume it's just a switch, closes when there' s no water at that level in the radiator. It sits between the oil lines (or are they transmission lines?) on the passenger side.
    -- A
  6. Russell
    Jun 23, 2000
    7,922
    333
    Ah, maybe it isn't so much a matter of the wiring and rather that my coolant is actually low, lol
    Better check it tommorow...
