Diesel Starting Troubles
Discussion in 'Pacific Region' started by XBeastX, Sep 25, 2003.
  1. XBeastX
    XBeastX Registered Member
    Apr 16, 2002
    27
    Beaverton, OR
    My girlfriend is having issues with her '90 Volkswagen Jetta diesel. It starts really hard in the mornings. It will turn over just fine. After a few tries to start it, it will start sputtering. After a few more tries it eventually starts. It starts fine the rest of the day, but only does this after it sits a while. Any ideas?
    Second question. Do any of you know of any trustworthy deisel or volkswagen mechanics in the Portland area?
  2. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    Try a small squirt of starting fluid when you have this problem. Sounds like glow plugs are not working properly (glow plugs or controller).
  3. ntaj*ep
    ntaj*ep 1/2 ton status
    Feb 4, 2002
    3,248
    Evergreen state
    IMO I would keep starting fluid as far away from a diesel as humanly possible, but again thats just me.
    How many miles are on it? And have the injection services been done? /forums/images/graemlins/thumb.gif
  4. XBeastX
    Apr 16, 2002
    27
    Beaverton, OR
    There's around 240,000 miles on it. /forums/images/graemlins/ooo.gif I'm not sure the last time the injectors were serviced, but I'll ask her. The funny thing is it just started happening out of the blue. It was starting just fine day before yesterday.
  5. k5blazerus
    k5blazerus 1/2 ton status
    Apr 22, 2001
    654
    Bend, OR
    Have you checked for air in the system
  6. BlueBlazer
    BlueBlazer 1/2 ton status
    Feb 15, 2001
    1,940
    Real quick thing you can do is check the fusible link for the glow plugs, my 82 Rabbit has one and I assume the newer VWs still have them. Mine is located on the firewall and was blown when I bought the car, replaced it and it started great from then on. Does it have a block heater? If so, plug it in for the night and see if it starts better the next day. If so, most likely glow plugs.
  7. ntaj*ep
    Feb 4, 2002
    3,248
    Evergreen state
    Check the water fuel separator if the fuse is OK. /forums/images/graemlins/thumb.gif
