Diesel swap parts needed
Discussion in 'Parts & Trucks Wanted' started by afroman006, Aug 30, 2004.
  1. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
    I am converting a gasser to diesel and need the following parts.
    Injection pump
    Injectors
    Glow plugs
    Exhaust manifolds (maybe)
    Fuel lines
    12 v Starter
    A/C brackets
    Vacuum pump
    Engine wire harness w/ a/c
    Cab wire harness
    Gauge cluster & bezel
  2. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
    I think you can use your same dash cluster from you gasoline truck. You just have to match the gauges with the correct sending units. IE the oil gauge needs to be calibrated for the corrosponding sending unit. Whether it be gasoline oil gauge and gasoline sending unit or diesel oil gauge with a diesel sending unit. Same with fuel gauge and temp gauge. I'm using a gas motor in a diesel tub and everything works fine because I used diesel sending units. I just cut out the diesel injection wiring from under the hood.
  3. afroman006
    Aug 21, 2002
    2,876
    Ok cool, I was just thinking otherwise cause the CUCV's have a slightly different cluster than gassers. So, anyone got any parts for me?
  4. Stomper
    Stomper ΜΟΛΩΝ ΛΑΒΕ GMOTM Winner
    May 11, 2002
    3,767
    Iowa
    Injection pump
    Injectors
    Glow plugs
    Fuel lines
    12 v Starter
    A/C brackets
    Vacuum pump
    I assume this is a 6.2 we are talking about?
    If so, I've got the above parts.
  5. doctor4x4
    doctor4x4 1/2 ton status
    Jan 22, 2002
    1,450
    Los Angeles
    i got all but 1
    also
    Injection pump
    Injectors
    Glow plugs
    Fuel lines
    12 v Starter
    A/C brackets
    Vacuum pump
    Cab wire harness MABE ???
    Gauge cluster & bezel (yes they are differnt ( for the W.I.F. sensors )
    all with my CK5 60 day $$ back guarante :-)
    pm me with what ya think is fair $$ wise
    Randy
  6. bigred81
    bigred81 1/2 ton status
    Dec 5, 2003
    323
    Falls City,TX
    Hello,
    Where do live in College Station because I am up here for the fall semseter and I know of a yard back at home that has most of the parts you will need. I have a friend who just changed out a 12 bolt 3.73 rear end for 14 bolt but he is hard to get a hold of because he is in the military.
    Send me pm.
    bigred81
  7. botboy
    botboy 1/2 ton status
    Aug 11, 2004
    225
    Delano, MN, USA
    I have a vacuum pump I'll be selling soon out of my '83 K5 with a 6.2, the selling because I want a tachometer and I'm going to get a 89-92 6.2 pump & pod with the speed sensor and rig up some circuitry to make it work with a factory tach cluster.
    botboy60 (at) hotmail (dot) com
  8. Trevor
    Trevor 1/2 ton status
    Mar 10, 2002
    160
    Auburn, Ca
    I have a complete crew cab diesel that has a running 6.2 with a turbo 400. It is missing the front axle, rear axle, and t-case. It was driving when I took it apart. If you want to drive to Gridley Ca. $700 for the whole thing.
