Diesel Swap worth it?
Discussion in 'The Garage' started by thefarside, Jan 28, 2004.
  1. thefarside
    thefarside 1/2 ton status
    Jun 27, 2003
    343
    Vernon, CT
    I have been planning on making the old 1980 Blazer in my sig to be used strictly to wheel with. My father’s friend has an older Cat diesel motor in his tow rig he will sell me for cheap. I was planning on putting a 383 in my truck originally but it is very tempting to switch to a diesel. I have never had or delt with a diesel before so I am lost with a swap like this. Would it be ok to wheel with? Also, would it be difficult to do a diesel swap?
    I tried to get the GM 2.5 ton axles from him be he would not budge. /forums/images/graemlins/frown.gif
  2. ben427
    ben427 1/2 ton status
    Mar 10, 2002
    1,123
    Waverley, Nova Scotia
    Better check on the size, if its bigger than a 3208 or 3204 it will probably be way to much hassle.
  3. thefarside
    Jun 27, 2003
    343
    Vernon, CT
    Are those casting numbers on the block?
  4. ben427
    Mar 10, 2002
    1,123
    No, those are model number. If you look around the block, there should be a little aluminum tag held on by 2 rivits, it will have the model,serial numbers, and arrangement number on it. What configuration is the engine?? a I4,I6, or V8? That will help on identifying it to an extent. Also what kind of truck is it in?
  5. Steve_87K5
    Steve_87K5 1/2 ton status
    May 26, 2000
    521
    central NC
    Diesel bug bit me too.
    What about a 3126 Cat??? too large?
    I decided to keep it in the GM family for ease of conversion, plus, many MIL surplus parts and marine parts available (6.5s in Humvees; Peninsular Diesel sells new-surplus 6.5 components)
    I found that GM dealers toss 6.5s in the dumpster for small problems. They provide customers new Goodwrench engine to keep 'em happy. If you can get on good terms with svc mgr, you might pick one up. They are not supposed to release this stuff however.
  6. ben427
    Mar 10, 2002
    1,123
    I think a 3116 or 3126 would be doable in a 1 ton with some lift for pan clearance. If you get one with mechanical injection it shouldnt be too bad.Run a clark 5 speed behind it and youd be in not bad shape.
  7. tRustyK5
    Jul 23, 2000
    36,166
    1,363
    E-town baby!
    I swapped a 6.2 into my Jimmy last year and haven't regretted it for a second. I was sick to death of the carb off road, and paying through the nose at the pumps wasn't too fun either. The diesel will run upside down (if it could maintain oil pressure that is...) and gets almost twice the fuel mileage.
    Off road it kicks butt, the low end grunt at idle makes driving 'elegantly' much more probable than ever.
    If my wheeling was mostly mud I'd probably keep a gas engine though, the diesels don't usually spin at very high rpm. The 6.2 does redline at a relatively high 3600 rpm though.
    Obviously my opinion is biased...but I'd run a 6.2 or 6.5 and call it good...hell they bolt right up. /forums/images/graemlins/waytogo.gif
    Rene
  8. thefarside
    Jun 27, 2003
    343
    Vernon, CT
    A large tow truck. I will take a look at it when I get the chance this weekend.
  9. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    I would try it if it's a 3208 or 3204 like ben427 said... What year is this tow truck? I think that a 3126 is a later motor but don't qoute me on that one. /forums/images/graemlins/doah.gif /forums/images/graemlins/thinking.gif
  10. steelsoldiers
    steelsoldiers 1/2 ton status
    Oct 17, 2002
    365
    Charleston, West Virginia
    I was reading on the Diesel Doctor site the other day and the guys were talking about what a PITA the CATs were to work on. They said that they require a lot of special tools and $$ parts.
    I have been looking at a bunch of different engines for diesel swaps like the Iveco, the Deutz, etc..., but I always end up coming back the the Cummins 5.9L. IMO they have the best power to weight ratio and the 94-98.5 are some of the easiest engines to get power out of. The others are real heavy. The CATs are over 1100 lbs easy! /forums/images/graemlins/shocked.gif
    That's just me though. It would definitely be different. I have never seen a CAT powered Blazer before. So, go for it if you are up to the challenge. /forums/images/graemlins/thumb.gif
  11. ben427
    Mar 10, 2002
    1,123
    Yeha the 3204 and 3208 have been out of production for a few years while there are still variations of the 3126 in production today. The on highway engine is now called the C7 ACERT, and there is still a marine 3126B im pretty sure. There is a fellow who regulars theis site wh works at cat who would know for sure, im surprised he hasnt chimed in yet. blueblazer or something like that.
  12. Thumper
    Thumper 1/2 ton status
    1,582
    Alberta Canada
    Rene, did you ever do a writeup on the swap? Id be interested in reading the problems you ran into. /forums/images/graemlins/smile.gif
    BTW, is it really as stinky and noisy as Id suspect it to be on a trail?
    /forums/images/graemlins/ignore.gif /forums/images/graemlins/thinking.gif
    Mike
  13. K1Orion
    K1Orion 1/2 ton status
    Jan 8, 2003
    812
    st.louis,MO
    NO
