diesel swap
Discussion in '1982-Present GM Diesel' started by bigbear8, Nov 29, 2001.
  1. bigbear8
    bigbear8 Registered Member
    Aug 28, 2000
    17
    New Jersey
    I was wondering if the 6.2 is a direct bolt up to the sm465, and what else i would have to change on my truck to make it run?
    thanks
    Bigbear 8
    What is that thing you speak of? Ford? Never heard of it.
  2. BlueBlazer
    BlueBlazer 1/2 ton status
    Feb 15, 2001
    1,940
    As long as the flywheels are the same between gas and diesel, which I think they are, it will bolt right up. The bellhousing patterns are the same. You will need all the diesel parts from a donor truck to make it work. Anything involving the glow plugs, fuel filters, radiator, etc. It will bolt right in with no problem. Its no different than swapping in a big block except for the before mentioned glow plugs and fuel filters.
    82 K5, 6.2L Diesel, sm465, np205, 14 bolt welded, 8 lug 10 bolt lock right, 410 gears, 35" Mud Kings
    SPEAK SOFTLY AND DRIVE A BIG TRUCK
  3. Tybee
    Tybee 1/2 ton status
    Mar 25, 2001
    1,565
    Centennial, CO
    I remember reading something about the fly wheels being different or maybe it was the torque converter, but you wouldnt have a torque converter with the sm465 anyways.
    1984 GMC Jimmy 379 diesel, 700R4, 3.73s, 31x10.50 x 15
  4. bigbear8
    Aug 28, 2000
    17
    New Jersey
    thanks for the info.
    bigbear8
  5. DSLBLAZER
    DSLBLAZER Registered Member
    Feb 21, 2001
    29
    California
    The flywheels are different. Make sure you get a 6.2 diesel flywheel. I converted my diesel blazer from an automatic 700r4 to a manual sm465. The 6.2 will bolt right up.
    Keven
