Diesel Tach
Discussion in '1982-Present GM Diesel' started by savagek5diesel, May 6, 2004.
  1. savagek5diesel
    savagek5diesel 1/2 ton status
    Nov 20, 2003
    310
    Redding California
    Hey guys, I saw that autometer makes a 5" in dash tach now and i was wondering if anybody knows if us diesel guys could use it somehow?
  2. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Autometer has offered the in-dash tachs for a long time. But I don't think they will work with a diesel engine.
    ATM-2888(summit part#) is a diesel tach. It has a small inductive probe that straps on the alternator to pick up the signal. I don't know if it's indash or what though.....
  3. BlazerGuy
    Apr 20, 2000
    9,206
    abcde
  4. BlazerGuy
    Apr 20, 2000
    9,206
    abcde
  5. BlueBlazer
    BlueBlazer 1/2 ton status
    Feb 15, 2001
    1,940
  6. Diesel Dan
    Diesel Dan 1/2 ton status
    Feb 27, 2002
    798
    Warren, Ohio
    Do a search on this topic.
    I gave part #s for a 3 5/8" Stewart Warner diesel tach that is carried by CarQuest. The pickup used a mag sensor off the flywheel teeth. Way more accurate than the alternator style.
  7. Steve_87K5
    Steve_87K5 1/2 ton status
    May 26, 2000
    521
    central NC
    In tearing down several 6.5s (discarded ones from dealer dumpsters) I found that some were equipped with timing teeth on the front of the crank (4 teeth). These used the short hub style harmonic balancer.
    If you are inclined to make your own tach circuit, check out the ATS610LSA sensor (hall effect). I'd like to use this sensor, and appropriate circuitry to make the OEM gas tach work in my '87 with the 6.5
    I think there were 2 different ESS methods used. One had a module mounted on the vacuum pump (California emissions) and another used a hall effect sensor on front of crank. Maybe others, not sure.
