diesel tach?
Discussion in 'The Garage' started by K5dreamer, Mar 11, 2007.
  1. K5dreamer
    K5dreamer 1/2 ton status
    Mar 14, 2005
    3,084
    Alexandria, Va
    hey all, im no stranger to putting a tach on a gas powered engine, but im kinda curious about putting one on a diesel. im lookin to put a small gas guage in the truck, and replacing the big gas guage with a tach.
    ive done a little searching and found mention of a optical pickup tach where you paint alternating black and white stripes on the harmonic balancer and position a optical pickup in order to measure rpms.
    my question would be, how does that work when you go mudding? or get water above fender level? has anyone setup something like that and had problems?
    ive also heard about magnetic pickups. which would probly work better, but i still have reservations about.
    are optical and magnetic pickup tach's the only option for a diesel owner who wants a tach?
  2. TSGB
    TSGB 1 ton status
    Apr 22, 2002
    12,527
    Centralia, Washington
    I have the same interests, but haven't done any research yet.
  3. k204dr
    k204dr 1/2 ton status
    Aug 27, 2004
    463
    TN
    you can take your alt to a shop and have them solder a wire to one of the diodes, and run it off that i've been told.
  4. AuH2O
    AuH2O 1/2 ton status
    Oct 4, 2006
    185
    FL
    How exactly were the factory diesel tachs wired up is what I wonder?
  5. TSGB
    TSGB 1 ton status
    Apr 22, 2002
    12,527
    I was chatting with my step-dad yesterday, he said there may be a sensor on the crank, but he doesn't know for sure.
  6. 80' 427
    80' 427 1/2 ton status Premium Member
    Nov 14, 2006
    4,089
    399
    NEBRASKA
    They use the alternator on a factory tach in a 6.2 and 5.7 diesel
  7. BKinzey
    BKinzey 1/2 ton status
    Jan 13, 2006
    3,145
    Hollywierd, CA
    Fill out your sig so we know what you have.
    The 6.5L has an optical sensor on the crank and if your Fuel Injection Pump is computer controlled, called a PMD, there may be more options as well.;)
  8. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,923
    333
    Fort McMurray, Alberta
    There is a later version of a vaccum pump that has a cam sensor on it, you can convert that signal to be used with a factory tach... I'm not entirely sure how it works, but I have a buddy who'd figured it out.
    I can email him and ask if you want :)
  9. TSGB
    TSGB 1 ton status
    Apr 22, 2002
    12,527
    That would be splendid. :D
  10. greythorn3
    greythorn3 1/2 ton status
    Oct 14, 2002
    174
    Anchorage alaska
    6.9 ford
    my 6.9 ford has a sensor that screws into the injection pump gear cover it looks like a magnetic pickup type.. but not positive.
    Ray
  11. Hitches31
    Hitches31 Registered Member
    Feb 18, 2006
    54
    Saginaw Mich
    I used an Auto Meter Diesel tack. It used the alternator as a pick -up point . very easy to install . It is adj for any diesel ( Ford, Dodge Chevy) I ordered it from Summit and it was I think $119.00 Shipped! I'll look for my Invoice for the part number!
  12. ccatlett1984
    ccatlett1984 1/2 ton status
    May 1, 2005
    161
    michigan
    please post that #, thanks
  13. Russell
    Jun 23, 2000
    7,923
    333
    Ah, totally forgot about this thread -- I'll send the email off right now
  14. Russell
    Jun 23, 2000
    7,923
    333
    Got a reply to my email:
    He would have to buy a vacuum pump from (Bumper to Bumper part# CDN*64-1202,
    GM Part# 7849303) and then build a little signal converter and plug it all
    in. There is a write-up by Lee Swanger on www.thedeiselpage.com describing
    how to connect any electronic tachometers to a deisel. Moody is a member who
    lives in edmonton and I going mine from him. The diesels did not come with factory tachs until the 3rd gen body style (88'+)
  15. TSGB
    TSGB 1 ton status
    Apr 22, 2002
    12,527
    Thanks boss, I'll check that out! :waytogo:
