diesel tachometer
Discussion in 'The Garage' started by k5blaz, Oct 20, 2004.
  1. k5blaz
    k5blaz Registered Member
    Oct 3, 2004
    22
    jonesborough TN.
    can somebody tell me how to hook up a tach. on a 6.2 and possibly where it's suposed to read line or if it has a red line. revlimiter seams to work well but i'd rather not blow it through the hood just yet. /forums/images/graemlins/k5.gif
  2. dheavychevy38
    dheavychevy38 1/2 ton status Premium Member
    Jan 6, 2003
    1,003
    Algonquin,illinois
    they have special tachs that read off a band off the alt or off the injection lines you can't use a regular tach
  3. k5blaz
    Oct 3, 2004
    22
    jonesborough TN.
    I was told it hooked into the injecter pump, lines something like that is this difficult to do.
  4. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    most feed off the alt.
    scroll down to the diesel forum and see if there was a post there, I know there was.
  5. k5blaz
    Oct 3, 2004
    22
    jonesborough TN.
    what about redline I'm used to big disels holding on revlimiter is fine. just not sure on 6.2 n/a. hell I did'nt even know it had a revlimiter for the first 4 or 5 years i had it.
  6. Diesel Dan
    Diesel Dan 1/2 ton status
    Feb 27, 2002
    798
    Warren, Ohio
    what about redline
    3600 RPM.
    Factory ran off either alternator or tach sender that ran off the cam like a distributor. Aftermarket has units that use glued on magnets on harmonic balancer or mag pickups that read the theeth off the flywheel.
    This was covered more under the diesel forumn.
  7. k5blaz
    Oct 3, 2004
    22
    jonesborough TN.
    is redline where the limiter hits or does it hit past red.
  8. tRustyK5
    Jul 23, 2000
    36,184
    1,392
    E-town baby!
    It'll run all day long at the governed limit without exploding...you're not gonna hurt it unless there isn't any oil in it. /forums/images/graemlins/smile.gif
    Rene
  9. k5blaz
    Oct 3, 2004
    22
    jonesborough TN.
    thanks alot everybody thats what I needed to know. Idid'nt think it would hurt it just wanted to be sure. thats basicaly how I drive my dump truck /forums/images/graemlins/smile.gif stand on it!!!!
  10. smprider112
    smprider112 1/2 ton status
    May 1, 2004
    624
    Beaverton,Oregon
    hey TRusty how do I know if mine has its governed revlimiter still?? I was driving once going up a hill, floored it at like 65 then it downshifted into 2nd, so I was kinda scared...it revved pretty high but it felt almost like it fell of the powerband and wasnt making anymore power....so maybe that was the limiter /forums/images/graemlins/dunno.gif
  11. diesel4me
    Jul 24, 2003
    17,583
    945
    Massachussetts
    My diesel feels like it runs out of fuel when it hits the govenor's limit in the injection pump(probably exactly what it does,shuts off the fuel!)or like you shut the key off,until the motor slows down enough,then it turns back on again--my TH400 makes my truck do this quite often--the electric downshift detent switch tells the tranny to go back into first gear at too high a speed if your not careful--it zooms up to 35-40 in first,then boohhhhgggggss out when the govenor kicks in,then goes into second with a lurch of power--it gets annoying somtimes--feels like it needs another gear inbetween second and first!.I have the vacuum modulater hooked direct to the vacuum pump too,that might be a factor too-- /forums/images/graemlins/crazy.gif
