diesel th400 behind my 305?
Discussion in '1982-Present GM Diesel' started by K10ANDYKHAMNIC, Jun 1, 2002.
  1. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    will this work ? will it bolt right up ? it came with a th350 its an 81 p/u 4x4 yadday yadda thanks
  2. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    Should. 6.2's use the chevy bellhousing (not the BOP). You will have to connect the vacume-downshift line.
  3. arveetek
    arveetek 1/2 ton status
    Mar 1, 2002
    722
    Granby, MIssouri, USA
    It will bolt right to the motor...no problem. The diesel torque convertor will have a lower stall speed, but I'm not sure how much.
    Isn't the 400 a different length than the 350? Will it bolt to your transfer case?
    Casey
  4. BigBluOx
    BigBluOx 1/2 ton status
    Aug 30, 2001
    301
    Auburn, WA, USA
    The 400 and 350 output shafts are different spline (30something vs. 27). Also, the 350 is longer. There are several adapters on the market to facilitate the changeover. You may have to change the output shaft on the 400 to connect to the x-fer case (or possibly the input on the x-fer).
    I've been looking at the options to put a 400 on my 'Burban since the 700 is broken.
    Laterz
    Jon
  5. K10ANDYKHAMNIC
    Sep 17, 2001
    1,962
    Western CO
    no the th350 is the shortest gm trans thats why jeepers like it .i have the t case angle covered got all the parts and everything .....
  6. BigBluOx
    Aug 30, 2001
    301
    Auburn, WA, USA
    Yeah....what he said ---^
    Jon
  7. calcide
    calcide 1/2 ton status
    Dec 21, 2001
    283
    Actually, the powerglide is about 5 inches shorter than the TH350. And almost all the manual trannys are shorter, too.
  8. K10ANDYKHAMNIC
    Sep 17, 2001
    1,962
    Western CO
    i was excluding that one cuz it only has 2? gears and it was never offered in our years of trucks .
