Diesel Tranny wiring.... Stand-alone??? Pleae look!
Discussion in '1982-Present GM Diesel' started by BigBlockBurris, Jul 9, 2006.
  1. BigBlockBurris
    BigBlockBurris 1/2 ton status
    Jul 27, 2002
    100
    Concord, NC
    I am parting down a 1991 R-3500 CC truck. It has a 6.2 diesel and a 4L80-E tranny. I believe I read somewhere (I searched and could not find it) that this is a desirable setup due to the fact that the tranny has a stand alone harness. Is this true?? Please explain. Thanks in advance.
    BBB:D
  2. CrewCab59
    CrewCab59 1/2 ton status
    Aug 13, 2005
    483
    Knoxville ,TN
    Yes ,the 4l80e have a stand alone controler.The trans is a verson of the Th400 but with overdrive.The trans won't work with out controler.
    What else do you need to know?
  3. BKinzey
    BKinzey 1/2 ton status
    Jan 13, 2006
    3,145
    Hollywierd, CA
    A 400 with overdrive? Is that the same as an electronic 700R4? That's what I've heard but other than an overdrive I couldn't tell you what the difference is between a 350, 400, or 700R4:doah:
  4. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    The only thing more desirable would if it was a '91 V3500 with a 6.2, 4L80E and a NP 205. :D
    Rene
  5. BigBlockBurris
    Jul 27, 2002
    100
    Concord, NC
    Thanks guys.
    Crewcab59,
    So this is a 100% stand alone harness. When I part the truck I should be able to remove the complete harness for future use? I guess what I am asking is that it does not need ANY input from the motor? It is 100% stand alone? The harness for the tranny is in the underhood harness loom, so I am just curious. If it is stand alone I am going to split the harnesses. Thanks
    BBB
  6. CrewCab59
    Aug 13, 2005
    483
    Knoxville ,TN
    No , the 4l80e isn't the 700R4 .The 700r4 was the replacment for the Th350 !
    The 4l80e replaced the Th400!
  7. BKinzey
    Jan 13, 2006
    3,145
    Hollywierd, CA
    Yep, missed it again:doah:
    It's the 4l60 I was thinking of. All I had to do was look at the cover of the ATSG THM 700-R manual I bought :rolleyes: Maybe I'll crack it again but last time I got such a headache:bow::haha:
  8. CrewCab59
    Aug 13, 2005
    483
    Knoxville ,TN
    Yes,
    You can remove the controler ,it setting behind the glove box.
  9. Jimbo*
    Jimbo* 1/2 ton status
    Mar 8, 2005
    1,420
    roswell, new mexico
    Ok, then I have a question along these same lines: I recently traded for a 1991 crew cab 2wd pu with a 5.7 and a 4l80e. Is my 4l80e a stand alone harness, or is it part of the tbi harness? If it's part of the tbi harness, where is the vss? Can I (hopefully) just remove the tailhousing and install the spacer and adapter and my 205?
    Thanks, Jimbo
  10. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    On the gas motors the computer for the tranny is going to be integrated in with the TBI stuff...
  11. Jimbo*
    Mar 8, 2005
    1,420
    roswell, new mexico
    That's what I thought. So, where's the VSS? I have a core 4l80 out of a 96, and there is no VSS on the tailhousing; is my 91 4l80 VSS internal also?
    Can I remove the tailhousing and install the spacer/adapter and 205 and be good?
    Thanks, Jimbo
  12. kennyw
    Jun 9, 2002
    13,224
    94
    If VSS is related to the speedometer it should be in the tailhousing of the tcase.
  13. azblazor
    May 5, 2001
    1,953
    Arizona, Phoenix area
    The 4L80E computer requires input frm the throttle position senson (TPS), the VSS and engine RPM.
