Diesel Transmission (3 speed to 4 speed)
Discussion in '1982-Present GM Diesel' started by aquaman02, Dec 14, 2002.
  1. aquaman02
    aquaman02 Newbie
    Dec 11, 2001
    4
    Tallahassee, FL
    Hey all,, have a question that I cant seem to find an answer to. I have a 1984 CUCV 6.2L with a 3 Speed THM-400 / 208 Transfer Case. It is mostly a road truck with some light off road use. I am not too fond of the high RPM's this thing is turning out and would like to make it a 4 speed. What do I need to do this.. Do I need to change the transmission to a 700 or can I just keep the THM-400 and swap the Transfer case for something else? Someone told me that I could just swap the transfer case and that would make it a 4 speed.. is this correct? /forums/images/graemlins/k5.gif
  2. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    I different t-case won't help. I don't know of any with better than 1:1 ratio in high-range.
    A TH700 will fit your engine, but you'd need a different t-case, or at least a different input gear in the t-case to make it work.
    There is an auxiliary overdrive made by Gear-Vendors. It will cost you. And only works in 2wd since it bolts onto the back of the t-case.
    Bigger tires or different axle ratios are your alternatives.
  3. arveetek
    arveetek 1/2 ton status
    Mar 1, 2002
    722
    Granby, MIssouri, USA
    Perhaps somebody was thinking of a Gear Vendors or US Gear aux. overdrive transmission when they told you about swapping transfer cases.
    Both of these aux. transmissions work like a two-speed axle. They have direct and overdrive. This allows you to split all gears, so your three speed is, in essence, a six speed.
    The GV unit bolts on behind the TC, and can only be used in 2WD mode.
    The US Gear fits between the transmission and TC, and can be used in both 2WD and 4WD.
    Both units are expensive.
    Swapping to a 700 would probably be cheaper, but is still difficult. You have to move the TC back, and modify the driveshafts.
    Casey
  4. JORGE
    JORGE 1/2 ton status
    Jan 10, 2001
    213
    VITORIA-GAZTEIZ(ALAVA)BASQUE COUNTRY,SPAIN
    Why he needs an other T-case?I have the Th- 700- r4 with the Np208 from factrory...
  5. u2slow
    May 9, 2001
    2,217
    BC Canada
    The TH700 needs a 27-spline t-case input. The th400 uses a 32-spline. Ech tranny has its own adapter too.
  6. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    I agree that if you are not into heavy fourwheeling, you're better off with a 700, the 208 you have will need to be changed or swaped for one that goes on the 700.
    Where are you at?
    Fill out some of your profile like what city are you at and what year your vehicle is and what upgrades if any you have done to it.
    That sometimes helps people point you in the right direction, and for me here, it would let me know if you are close enough where I could trade you what you need. /forums/images/graemlins/smile.gif
