Diesel Vs. Gas Radiator
Discussion in 'The Garage' started by ARAMP1, Nov 15, 2006.
  1. ARAMP1
    ARAMP1 Aviator Extraordinaire
    Sep 1, 2005
    3,983
    55
    Memphis, TN
    Anyone know off hand what the difference between the radiators of a 454 truck and one with a 6.2? Is it 3 core versus 4?
  2. steve_kibbe
    steve_kibbe 1/2 ton status
    Feb 4, 2004
    2,895
    Spartanburg, SC
    The diesel is alot wider iirc.
  3. desertrat67
    desertrat67 Hawk Driver
    Jul 5, 2001
    3,982
    74
    Dumfries, VA
    The tranny cooler is on the left side on the diesel(driver's) and the right on the 454. I tried to get one from a CUCV for my crew cab for a spare, but saw the different line routing and said forget it.
  4. steve_kibbe
    Feb 4, 2004
    2,895
    Spartanburg, SC
    The oil cooler hookup is on the drivers side too.
  5. JpEater
    JpEater 1/2 ton status
    Nov 20, 2005
    299
    Augusta, Georgia
    Same size radiator. 34" core 4 Row. Just the hose necks are different sizes and the coolers are opposite sides.
  6. Jimbo*
    Jimbo* 1/2 ton status
    Mar 8, 2005
    1,420
    roswell, new mexico
    No, they are not the same size. The 6.2 rad is about 6-7" wider, they are both 4 row, and like has been said, the tranny and oil coolers are reversed.
    The 6.2 is easy to put into a rig with a gas motor, just have to splice the upper rad hose 'cause nobody makes one for that application.
    Jimbo
  7. ARAMP1
    Sep 1, 2005
    3,983
    55
    Memphis, TN
    Okay, I’ve got no coolers at all in the radiator; just an in and an out and a separate return from the heater core. (Manual trans, separate oil cooler) But, there’s different part numbers for gas and diesel. I want as big of a radiator that will fit in there, but I obviously want it to fit.
  8. Jimbo*
    Mar 8, 2005
    1,420
    roswell, new mexico
    I'll get pics of the comparison tomorrow--you want a 6.2 radiator.
    Jimbo
  9. ARAMP1
    Sep 1, 2005
    3,983
    55
    Memphis, TN
    Jimbo,
    If you could, I'd appriciate it.
  10. mrk5
    Apr 20, 2004
    12,349
    1,050
    Northern Colorado
    What year truck front clip are you putting it in? If it's an 81 or later, it'll fit just fine. The provisions are there for the wider diesel radiator. I still run the diesel radiator with my 350. I can see where bolt holes are that would mount to top bracket in narrower. I want to say it's wider towards the driver's side. I've thought about a dual snorkel air cleaner, but the radiator blocks the cutout on the driver's side. That'll give you an idea how wide it is.
    I would take a diesel 3-core over a gas 4-core.
    As stated the outlet/inlet on the rad is bigger than gas. I was able to get a universal type radiator hose on the bottom and I used 2 different hoses on the top with a huge barbed union. I got the union from a farm irrigation supply place. The top hoses were some type of factory hose, I just looked through the Carquest catalog at various picture to find 2 with the right bends.
  11. steve_kibbe
    Feb 4, 2004
    2,895
    Spartanburg, SC
    The diesel radiator I have is 41" tank to tank, and the core is 34" wide.
    It is a 4 core radiator.
  12. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    The diesel radiator is bigger
  13. jdemaris
    jdemaris Registered Member
    Apr 10, 2001
    76
    Radiator
    6.2D diesel radiator can be two, three, or four rows in the core. Many of the two-row radiator actually have more capacity then the four - because the rows are much wider. Also, the diesel application has the oil-cooler lines, and the low-coolant sensor port. If you need more specs., let me know. I've got over a dozen spare radiators I can measure - of every variety.
  14. DesertDueler2
    DesertDueler2 1/2 ton status
    Dec 25, 2004
    132
    Chandler, AZ
    Also if you have serp. setup, the stock upper hose will not fit with the diesel rad.. It hits the alt. because you have to stretch it over.Dan
  15. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Big Block radiators vary in size. The one in my Dad's '79 is a 34" 4-row core, but no engine oil cooler. Dunno about the hose fitting sizes. The other rad I've seen with the 454 is a 28x19" core... whereas the smaller engines are most often 28x17" core.
    When I needed a rad for my 6.2L, only 4-rows showed up in parts books.
  16. JpEater
    Nov 20, 2005
    299
    Augusta, Georgia
    I have a 6.2 radiator in my BB K10 and its a 34" core. I also have a radiator out of an 89' V3500 w/454 and what do you know its also a 34" core. The only difference between the two in front of me is the neck sizes and coolers are opposite. They are also both 4 row.
  17. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    i find this interesting, that GM installed a bigger radiator in the Diesels, over the gas engines, being that Diesel engines burn cooler anyways,,,,weird,,but anyways,,,carry on:D
  18. twodollars
    twodollars Registered Member
    Jul 19, 2006
    49
    Wayne, MI
    The 6.2, and 6.5 are idi engines, and since conbustion starts in a pre chamber in the head, deposit a great deal of heat into the cooling system.
  19. mrk5
    Apr 20, 2004
    12,349
    1,050
    Northern Colorado
    I have my diesel radiator the the serpentine setup on the 350. Just depends on how you run the hose.
