diesel vs. gas steering pump same?
Discussion in 'The Garage' started by muddybuddy, Mar 18, 2007.
  1. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    is the steering pump from a diesel the same as one from a gas? id use it with a steering box ment for an older truck (flare style lines, instead of o-ring that is currently on truck). im running the same setup on my gas truck with the flare adapter (#1 in the pic below). what i want to know is, will i be able to do the same thing on the diesel pump, or is there more than one line that is different (more than one fitting that needs to be swapped out)? hope that makes sense:doah:
  2. mofugly13
    mofugly13 1 ton bucket of rust Premium Member
    Oct 6, 2002
    2,813
    San Francisco
    AFAIK, a diesel pump is the same as a gas engine hydroboost pump. I used a diesel pump on my K5 when I went hydro.
  3. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    so then that should be the only fitting i have to swap right?
