Diesel won't start
Discussion in '1982-Present GM Diesel' started by KRUM, Mar 20, 2003.
  1. KRUM
    KRUM 1/2 ton status
    Dec 17, 2001
    159
    Signal Mtn
    Diesel won\'t start
    my glow plugs arent working if the engine temp is 100 degrees or more and it wont start unless they are cycling
    any ideas? it won't even hit a lick unless the GP light comes on i have listened to the GP relay and its not cycling. any ideas? /forums/images/graemlins/1zhelp.gif
    thanks,
    Jerry
  2. Txstruck
    Txstruck Registered Member
    May 25, 2002
    87
    Seagoville, Texas
    Re: Diesel won\'t start
    If the relay is not cycling, it could be bad or the temp sensor is thinking it is hot enough and not kicking it on. I havent messed with my GP system yet but i can send you a schematic if you want.
  3. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    thanks,
    Jerry
    This is the reason some people put a switch and bypass the controler.
    Do a search and you will find the direction on how to rig one up, or you could change the controler.
    /forums/images/graemlins/thumb.gif
  4. KRUM
    KRUM 1/2 ton status
    Dec 17, 2001
    159
    Signal Mtn
    thanks guys but i may have just had a loose wire /forums/images/graemlins/smirk.gif. but one thing thats bothering me is it would'nt hit a lick and it was like 75 here on the mountain but when i fully connected the loose wire it fired right up?
    thanks,
    Jerry
  5. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    thanks,
    Jerry
    When you have a loose wire, as soon as you have a high demand in current it will disconnect, the small area that is touching will act like a fuse and burn and no more contact.
  6. KRUM
    KRUM 1/2 ton status
    Dec 17, 2001
    159
    Signal Mtn
    ok i was wrong about the "loose conection" but i did finally find the problem it was the little in-line temp switch for the gp system i bypassed it and it is working fine dont know why it even got one it works fine without it
    thanks,
    Jerry
