Dieseling....HELP!!!
Discussion in 'The Garage' started by broncoman6524, Sep 8, 2006.
  1. broncoman6524
    broncoman6524 1/2 ton status
    Oct 31, 2005
    2,469
    chuluota Fl
    so my truck has revently started dieseling, it has gotten progressively worse.:( at first it was just like a pshh sound and not it continues to run and i have to turn the key to run, itll start, and then shut it off. Then it MIGHT turn off. ITs getting pretty damn annoying and embaressing...:haha: im kinda concerned about what it could be.
    carb 350, edelbrock 1406 carb, performer intake, msd 6a box. HELP!!!!!!
    my only thoughts are too far advanced timing, or a loose ground? hopefully? maybe lol
  2. Roland_Jenkins
    Roland_Jenkins Registered Member
    Apr 14, 2006
    58
    Newport Washington
    Could also be to lean. Rich-en (turn) the air fuel screw a tad.
    Bad gas, low octane will do it too.
    Wrong spark plugs, wrong gap, worn spark plugs are other possibilities.
  3. broncoman6524
    Oct 31, 2005
    2,469
    chuluota Fl
    wrong plugs? seriously!? how can i tell whrether or not theyre the wrong ones? lol i though it didnt matter. lol
  4. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
    Ethanol blend gasoline can sometimes do this in a carbureted engine. Are you running straight regular, E10, E85?
    Until you get the actual cause diagnosed, you can shut it off in gear to avoid the embarassment of chugkachugchug.
  5. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,992
    130
    Carbon deposits can cause dieseling as well. All the other causes I know of have been said already.
  6. JEBSR
    JEBSR 1/2 ton status
    Dec 23, 2004
    1,541
    Clarksville, TN
    The most common cause is idleing to high, timming to far advanced or running to hot. Although the other answeres are of course possible too.
  7. broncoman6524
    Oct 31, 2005
    2,469
    chuluota Fl
  8. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    i had an 85 that dieseled after it got good and warm.
    seafoamed it and it never did it again to my knowledge. ran a lot smoother and quieter tooo
  9. broncoman6524
    Oct 31, 2005
    2,469
    chuluota Fl
    when you say seafoamed it did you put it in the tank right? i havent been able to find htis stuff, where did you get it?
  10. MattK
    Jan 12, 2005
    1,713
    Dallas, TX
    i sucked about half of it through the brake booster vacuum line(first slowly, then at around half a can i tipped it enough to stall the motor.) then i poured the rest in the tank. it'll smoke like hell, but thats supposed to be all the bad stuff gettin blasted out.
    both o'reilly and autozone carry it here.
  11. stkcode
    stkcode Registered Member
    Nov 30, 2005
    86
    Apple Valley, CA
    It might be a good idea to also check your vaccum hoses if you have the butt load of vaccum hoses to operate the smog goodies, as I do (hopefully not for much longer :D). Almost every 2 -3 years, I get a dam leak somewhere and the motor starts to diesel.
  12. 1985_K5_Silverado
    Dec 21, 2005
    984
    Corn Country
    That's a great suggestion for a pretty cheap and easy project (replacing all the old-looking vacuum hoses) for an engine that has a bunch of miles on it (and its vacuum hoses). You can't always see those teeny hose cracks that easily, even in the best of light. A 50 foot roll of good vacuum hose is only about 20 bucks.
  13. Rolled
    Rolled 1/2 ton status
    Jun 16, 2002
    683
    Anchorage, Alaska
    an easy way to check for vac leaks is to spray carb cleaner on the fittings and lines. If the idle changes, you have a leak. Just be sure the overspray does not get in the carb or else you will get false readings.
  14. broncoman6524
    Oct 31, 2005
    2,469
    chuluota Fl
    actually i get a pshhing sound after i shut off hte motor...that is probaly a leak.:doah: im retarted well, ive got 3 cans of carb cleaner and im GOING to find the leak or whatever the hell problem this is TODAY/ :D eh hopefully
  15. 454k30
    454k30 1/2 ton status GMOTM Winner
    Sep 13, 2004
    1,613
    California, MD
    For me it is usually carbon deposits or to high of an idle speed.
  16. 02turbogixxer
    02turbogixxer Registered Member
    Aug 1, 2006
    63
    Dallas, TX
    I know what you mean about being embarased. I went to the bank last weekend and I pulled up to the front door and I turned the key off and made it to the door before the f***er finally shut down. :doah: Two people in the parking lot were looking at my Blazer like WTF is up with that piece. I just wanted to yell out "That ain't mine!"
  17. MattK
    Jan 12, 2005
    1,713
    Dallas, TX
    :haha: i hate gettin embarassed like that. the worst ive done was a blown front axle shaft on the way home from wheelin.even with teh hub unlocked, it was binding and not allowing the wheel to rotate backwords. i had to really get on it just to back out of the parking space:haha:
