dieseling
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by eshorvath, Dec 25, 2002.
  1. eshorvath
    eshorvath 1/2 ton status
    Jun 20, 2002
    373
    Southern Oregon
    When I turn my blazer off, it continues to run. What can cause this?
    Eddie
  2. Doug M
    Doug M Registered Member
    Nov 8, 2002
    39
    Houston
    Idle speed too high, timing, top end carbon deposits, gas quality, carb needs rebuilt.
  3. eshorvath
    Jun 20, 2002
    373
    Southern Oregon
    Timing set at 6 btdc
    Newly rebuilt engine. Less than 600 miles
    New Carb
    Idle at 700rpm i think
    Manual
  4. hammer
    hammer 1/2 ton status
    Aug 29, 2001
    449
    Binghamton N.Y.
    you didn't say what carb it is. both holley and eldelchoke are not tuned for your application 100% everything still needs to be fine tuned after they are put on the truck
  5. Doug M
    Nov 8, 2002
    39
    Houston
    My Blazer is stock, with all the emissions stuff still there. I have found out it prefers 12btdc. You will notice a performance increase if bumped up a little as long as it's not pinging. I am connected to full manifold as per the hose routing diagram, QJet is not electronically controlled. I'd try timing, be sure there are no vacuum leaks and check the cats for flow. Maybe you can come up with something if you try a search.
  6. eshorvath
    Jun 20, 2002
    373
    Southern Oregon
    edelbrock 1406
  7. hammer
    Aug 29, 2001
    449
    Binghamton N.Y.
    If I remember right the only thing on a edelchoke you can do is adjust the two front screws to the max vacumn setting.
    Sorry gave up on elelchokes a while ago Holley is the only kind I play with now
  8. hammer
    Aug 29, 2001
    449
    Binghamton N.Y.
    There is something to do with the choke setting for electic choke that will make it diesel if it isn't set right
