Diet before mud drags
Discussion in 'The Garage' started by crazyrc, Aug 29, 2003.
  1. crazyrc
    crazyrc 1/2 ton status
    Jan 20, 2003
    106
    Northern Alberta, Canada
    Wondering if you guys think it would be worth my time to remove the bed from from my short box for the upcoming mud drag. Competition will be fairly stiff, but I don't know if the weight savings would be worth the time.
  2. ben427
    ben427 1/2 ton status
    Mar 10, 2002
    1,123
    Waverley, Nova Scotia
    Well i would think that youd want less weight on the front and more on the back to help traction, take the box off, and you may not be able to "hook up" as hard.
  3. Emmettology 101
    May 9, 2000
    8,126
    FL
    Ya, I would keep the box for traction weight. You do want to be light but not too light. I ran about 3 years ago at a local fair. I ran stock class with my '82 Jimmy. I left just about everythign in it that I normally run except for a big cooler. At the time I had a tired 305... I ended up it the top 2 and got beat out by a SWB Chevy, but I gave him a good run. What you need is good reaction times and traction. I got good traction because the 305 couldn't really break the tires loose but yet it got the Jimmy movin. I also still had on my top and rear tire carrier with spare.
    If you have a good runnin engine that can launch hard you may benefit by adding some weight! Adding ewieght you can add traction. The rest of the guys will go for all lighteweight but then you sacrifice traction and if you are spinning the tires you're not grabbing and going.
    See if you can get a look at the track a few days before the event.. I forgot to ask about what the track type was like..... But I just re-looked at the title and you said mud drags. So you may want to think a little different than what I said above. THat worked great that night on a dirt track that was hard with just a little loose stuff on top. That same night in the bogs, I think I got 5th... I didn't have the HP to get me through the mud fast enough. And in the mud I would try and go as light as you can but not too light. Keep the bed. Try and find a area where you can practice your launches and maybe play with different weight set-ups.
    Just my .02cents. Good Luck! /forums/images/graemlins/thumb.gif
  4. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    leave the bed but you can take off the tail gate and tool box if you have one
