diff. between 6 lug & 8 lug knuckles
Discussion in 'The Garage' started by chasone64, Nov 27, 2005.
  1. chasone64
    chasone64 Registered Member
    Dec 15, 2004
    88
    Oregon
    I have a freind that will give me a pass side flat top d44 knuckle!!! :D
    Only problem it's off a 6 lug d44.
    What is the difference, if any, between a 6 lug and an 8 lug knuckle. It's not close enough for me to look at & don't want to drive that far if it's not worth it...
    Any info is appreciated!! :bow:
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    the knuckle them selves are the same, its everything else outward from the knuckles. everything will interchange also.
  3. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Isn't the TRE taper bottom-up vs. top-down?
  4. RaisedK5
    RaisedK5 1/2 ton status
    932
    Long Beach, CA
    If you dont want to read it all, start reading under the picture.
    ORD Crossover
  5. dremu
    Feb 27, 2000
    15,951
    440
    East of San Francisco
    As U2Slow points out, it's important to have matching knuckles, unless you're doing high steer. If you can, get BOTH knuckles from your friend.
    The 6-vs-8 lug thing is a non-issue. The spindle and rotor are the deciding factors there.
    -- A
  6. chasone64
    Dec 15, 2004
    88
    Oregon
    That's what I thought - thanks.
