Diff breather advice
Discussion in 'The Garage' started by AussieK5, Nov 16, 2004.
  1. AussieK5
    AussieK5 1/2 ton status
    Jun 17, 2001
    316
    A land girt by sea
    After I pulled the engine from my latest truck I noticed the front diff (10 bolt) breather attachment loose, on the housing, and several years of crap had plugged the hole where it once sat. This explained the shite state of the gears and oil...
    Ive hit it with compressed air in an effort to clean the void out. Most of the crap came out through the bearing and some through the small internal cast holes.
    Any diff men got advice on a quick way to sort this problem...flushing, unbolt caps, leave it?
    Note: I only need this diff to do approx 5000 miles before I will replace with 1 ton gear.
    Jason
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    tap the hole and install and threaded barb.
  3. AussieK5
    Jun 17, 2001
    316
    A land girt by sea
    Sound advice.....but I'm kinda looking for insights on presence of crap in that void adjacent the bearing.
  4. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    spray the bearing the best you can with brake clean while turning the carrier. that should get most of it out and last well after your swap.
  5. AussieK5
    Jun 17, 2001
    316
    A land girt by sea
    Good idea.... /forums/images/graemlins/thumb.gif
    cheers
