Diff breathers
Discussion in 'The Garage' started by stockk5, Jan 14, 2005.
  1. stockk5
    Apr 13, 2004
    2,037
    73
    Cromwell, CT
    a quick question on diff breathers, how should i extend them? im not sure if this is right but the way i would do it is just to put a regular fuel/clear line over the original metal fitting on the end of the hose and just clamp it w/ a hose clamp. Is this the correct way to do it? Does the metal end need to be the absolute end of the hose? Should i extend the transfer case breather as well. Is there one for the tranny, i have a 700r4 i couldnt find it when i was looking for it.
  2. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Yeah any regular hose will do, just take them up high. Do the t/case as well. Trans have a hole near the top on the side. You can't put a breather pipe on as there is nothing to attach it to. On my TH350 when I rebuilt it I tapped a thread in there so I could put a breather on.
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I seriously thought about hooking mine together, but I didn't. :)
    Use 5/16 hose.
  4. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Are there any other "breather" holes to watch out for? I have reiased the diffs, doing the transfer case to day.
  5. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Some trans' have a little plastic tube for the breather. It's usually near the top, on the passenger side, near the base of the b/h. What I've done is find some vacuum tube that fits tight over the plastic tube. Then fit the fuel hose over that. On the Project YJ (LS1/4L60E/D300) I used a double wrap of safety wire on the vacuum tube to hold it onto the plastic tube (too small for a hose clamp) and did the same thing again where the vacuum hose fit inside the fuel hose b/c there wasn't room for a hose clamp. I manifolded all four vent hoses together and used a K&N breather.
