Diff carrier re-assembley
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Kia, Apr 7, 2004.
  1. Kia
    Kia 1/2 ton status
    Jan 26, 2002
    109
    Breda, The Netherlands
    I'm putting my blazer back on the road and having problems with the carrier going back into the bell housing.
    I have put the shims on both sides and then the bearing housing on that but the whole thing seems to be a bit tight.
    It's going in but don't know how much force i should use to get it in there.
    Shall I use a hammer? a mallet? kick it?
    AAAGGGHHH HELP!!!! (please) /forums/images/graemlins/ears.gif
    Kia.
  2. 85m1009
    85m1009 1/2 ton status
    Jul 11, 2000
    718
    Missouri
    It should be a snug fit. I usually use a deadblow hammer or a brass drift to convince them to go in.
  3. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    It'll be tight, i usually hold the shims on the ends with the races and all, kinda tricky, but i have had no real problems with it. Once it's started, i just tap it in with the hammer slowly, not hitting it too hard, but hard enough to get it in.
  4. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Put the races on the bearings, put the shim for the left side against the race. Set in in the housing. Then, keeping the race straight, wedge the right shim inbetween the race and housing. Tap the shim in with the cap, if you dont tap the shim in with the cap, it will break.
  5. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Put the races on the bearings, put the shim for the left side against the race. Set in in the housing. Then, keeping the race straight, wedge the right shim inbetween the race and housing. Tap the shim in with the cap, if you dont tap the shim in with the cap, it will break. Pry bars to get the carrier back out.
  6. dyeager535
    26,976
    You are saying (which the original poster apparently is not doing) is to install the carrier and one shim all the way, THEN insert the last shim, no?
    IIRC thats how it is supposed to go together, not shims THEN the carrier.
  7. Kia
    Kia 1/2 ton status
    Jan 26, 2002
    109
    Thanks for all that Guys, gonna try it all tomorrow morning /forums/images/graemlins/smile.gif
    (It's about 2am here in the UK at the mo /forums/images/graemlins/rolleyes.gif)
    Kia. /forums/images/graemlins/ears.gif
  8. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Thats what im sayin'.
