Diff fluid change ?'s
Discussion in 'The Garage' started by chev4life, Feb 7, 2005.
  1. chev4life
    chev4life 1/2 ton status
    Jun 21, 2001
    416
    San Jose, CA
    Need to change fluid on my 14bolt w/detroit locker...what is a good weight and brand to go for? Also...should I use a paper gasket or a liquid gasket? Would black gasket goo work?
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    How often do you run water or mud? If not often I would recommend what I use. I run Redline Heavy Shockproof gear oil. It is not cheap like dyno oil but it is a full synthetic and is very good stuff. It is roughly a 75W-250. I use RTV for gaskets on differentials. Seems to work fine for me.
    Harley
  3. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    I would only use synthetic gear oil if you keep it out of the mud and water. It only costs a couple extra dollars for synthetic over dyno oil. It will keep the gears cooler and break down slower than dyno oil, and in an area like a rearend that is almost always neglegted, an oil that can resist breakdown and wear the longest should be used IMHO.
    I use both the paper gaskets and high tack RTV.
  4. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    Wal-mart brand O.K.?
  5. chev4life
    Jun 21, 2001
    416
    San Jose, CA
    I like the mud and the water, but would like to put synthetic in. I talked to a detroit locker guy at SEMA this year and recommended not running synthetic on the lockers...has anyone ever heard this? What weight do I run if its not synthetic?
  6. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    For dyno oil I would use 85w140, or 80-90. For synthetic I used Mobile 1 syn. 75w-90 in my D70. I would have prefered a little heavier oil but got it for free so I can't complain.
  7. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    My rear axle is welded so that isn't an issue with my synthetic fluid. My lockright has been in synthetic fluid for the 3 years I have had it and for awhile when the previous owner ran it.
    Lots of people complain that there lockright is loud, but I have never heard a sound from my lockright with my thick synthetic fluid that I run.
    Harley
  8. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Red line is good. If not 80-90W is fine. And silicone, no gasket.
  9. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    I am running open diffs, but I used Mobile 1 synthetic - 75w-90 - per the recommendation of many members. I also used an original GM gasket with a very thin coat of RTV in the rear and just RTV in the front. Takes about two gallons to do both axles.
  10. ssls6
    ssls6 Registered Member
    Jan 5, 2005
    86
    Dallas, TX
    I like Schaeffers #267. It contains moly and climbs really well.
  11. bigyellowjimmy
    bigyellowjimmy 1/2 ton status
    Jan 15, 2004
    2,105
    Chandler, AZ
    I use Valvoline 80W/90 but I dont travel at high speeds or loaded, if it was a highway/tow rig I'd use synthetic :thumb:
  12. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I also run Redline , on Harley's reccomendation , for 4 months now with no problems . It likes to stick to everything , which is good . I swapped axles from my 3.08's to my 3.73's , whole housings , and when I went to roll the project truck which has teh old axles now , the damn thing still has a pretty good coating of Redline on it , and no surface rust from the morning dew :D
  13. chev4life
    Jun 21, 2001
    416
    San Jose, CA
    So I will see if I my parts store has a gasket if not I will just use RTV. How high much do you usually put in when refilling? I have a 14FF and dana 44 that I will be doing. I will also see what my parts store has in terms of fluid, I am a big fan of modil 1 from my SS so maybe I will go that route.
  14. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    I don't really remember how much the 14's hold but I just changed the oil in my D70 and it seemed to hold about 6 quarts, hard to tell because I was using a hand pump and a 5 gallon bucket. THere is a plug in the side of the diff, on the pass. side IIRC. Get it out with your 3/8" ratchet and fill through that hole until oil starts to spill out the bottom of your plug hole.
  15. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    You know it! In the D70 under my DOdge cummins I run syn. because it sees high speeds and tows a lot. Obviously that would cause the most heat and wear, and that is where the synthetic should shine. In my K5 that just sees short high speed bursts and slow wheeling I use any 80-90 dyno oil :thumb:
  16. chev4life
    Jun 21, 2001
    416
    San Jose, CA
    Yeah, I get alot of highway miles...even when I do wheel...got to get there. I am thinking of useing the 75x90ns Redline, my parts place has it in stock...I figure I will just clean their stock out :D. Yeah I figured that is what I do with the fill hole...thanks for info!
  17. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    For my trail truck with D60/FF14 combo with Detroits in both, I use Coastal 80W90 that I buy in a 5 gallon bucket. I change it out every six months or so in the front and yearly in the rear. More often of course if I run deep water or mud. Also, I prefer RTV to paper gaskets for differential covers. In my street driven truck, I used Mobil 1 75w90 with good results.
