diff fluid?
Discussion in 'The Garage' started by smokkey1, Jul 9, 2005.
  1. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
    so how much dose an 14ff take? I'm in the middle of swaping out the 14sf for the FF and down to point of putting in the fluid.
  2. smokkey1
    Jan 7, 2004
    2,677
    Los Angeles, CA
    2-3 quarts?
  3. mtnman210
    mtnman210 1/2 ton status
    May 30, 2003
    3,880
    Northridge, Ca
    I just did my front dana44 and it took 2 full bottles so I'd guess the 14 would be closer to 3 but I don't know for sure.
  4. scrappy88
    scrappy88 1/2 ton status
    Mar 14, 2003
    314
    Loveland, CO
    My Chevy service manual says 3.25 quarts for the 14b ff and sf.
  5. smokkey1
    Jan 7, 2004
    2,677
    Los Angeles, CA
    alright thanks
  6. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    3-4 quarts. I used almost a complete gallon in my Dana 70 under my Dodge.
    When you fill the rear end (assuming it's bolted in place under the truck) just fill it to the bottom of the plug hole.
  7. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    I usually jack up only the passenger side and fill it to the bottom of the fill hole and re-instal the plug. Then I let it down and jack up only the driver side for a few minutes and let it down. Then check it when it's sitting level to be sure it's still full. I did it this way when I swapped to disc brakes because I wanted to be sure that the oil made it into the hubs. Mine took almost 4 quarts.
  8. smokkey1
    Jan 7, 2004
    2,677
    Los Angeles, CA
    thanks for the tips guys.
    got to late so I'll do it tommorow. so tired from wrestling with the 14sf and 14ff.... anyways I got the pig under there just need to hook up the lines for the disc brakes and fill her up...
  9. earl87gta
    earl87gta 1/2 ton status
    Apr 6, 2003
    551
    Chuckey TN
  10. smokkey1
    Jan 7, 2004
    2,677
    Los Angeles, CA
    email sent :D
