Diff gear set-up
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Thumper, Jun 13, 2000.
  1. Thumper
    Thumper 1/2 ton status
    1,582
    Alberta Canada
    Does anyone have a link or a reference to an article detailing how exactly to set up rear gears? You know the ones with the pics of the pattern where the pinion is running, where to shim what and when? Im having a little trouble figuring it out by trial and error.
    Mike
    <font color=blue>Thumper
    85 Fullsize Jimmy
    <font color=red>Lets Go Wheelin! </font color=red>
  2. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    Mike,
    Check Randys Ring and Pinion at http://www.ring-pinion.com/TechLibrary.html This page has some very useful info in setting up your dif. Click on the link above then go to Four Critical Ring and Pinion Settings. This should help you in setting up your gears.
    Mudzer 1978/91 K5
  3. BlazerBoy
    BlazerBoy 1/2 ton status
    639
    Chicago IL.
    Just a tip that I learned to setting up my rearends. I took the old Bearing and machined it out just a tad so that it didnt have to be pressed in and out (since it isnt good for the bearing anyway) every time to change the shims. So there for I could Play around with the shims until I go the correct pattern then take it in and have it pressed on once....
    BlazerBoy
    http://generalblueballs.coloradok5.com
  4. AZK5
    AZK5 1/2 ton status
    Feb 22, 2000
    448
    Chandler, AZ
    I like using the GM shop manual. I have the full set for the 1986 Trucks. They tell you every detail of what to do.
    CB
