Diff Oil issue
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 79GM, Dec 4, 2001.
  1. 79GM
    79GM Newbie
    Dec 4, 2001
    I know this is beyond newbie and the only resason i dont know how to do it is because i havent done it before. im hoping i dont get flamed but i cant seem to figure out how i would change my differential oil. I know i could remove the differential cover but how can i put oil back in without it all spilling out. Thaks alot.
  2. FatBoyBlazer
    FatBoyBlazer 1/2 ton status
    Feb 22, 2001
    1,508
    Worcester, MA
    there a hose that connects to the differential, find the top and then fill it up with like 80W90 gear lube
    hola
  3. nofeartruckin00
    nofeartruckin00 1/2 ton status
    Oct 5, 2001
    798
    Germantown, Wisconsin
    Once you drain it, put the cover back on, and on the front of the diff where the pinion is, there should be a fill plug.
    Mud...
  4. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    There should be a fill hole on the side of the diff. On my 10 bolt it is on the passenger side. It is round with a square indentation. A 3/8" extension fits into the square indent. Take out the plug, and fill with gear oil until it starts to poor back out the hole. Then put the plug back in.
    My Chevy isn't broken, its just out of gas.
  5. rampage
    rampage 1/2 ton status
    Mar 20, 2001
    2,261
    74
    Humboldt/Pacifica, CA
    Remove the diff cover to drain the fluid. This is the preferred way because you get to check the condition of the diff also and see if there are any metal shavings in the bottom of the case. Make sure you clean the surface off completely before putting the cover back on or else it will leak. I use blue RTV instead of a gasket to reseal it. There should be a plug on the passenger side near the front of the pumpkin that you remove in order to fill it up. Newbie questions are always welcome here .. the only dumb questions are the one's you don't ask [​IMG]<P ID="edit"><FONT class="small">Edited by rampage on 12/04/01 06:55 PM.</FONT></P>
  6. Can Can
    15,555
    156
    Cochrane, Alberta, Canada
    And after all the oil has drained spray some BrakeKleen into the housing to break up and flush out any accumulated crud. I use a whole can per diff. Make sure to scoop out any leftover residue with a rag and let the BrakeKleen evaporate before sealing the dif back up and refilling it.
    BTW, here in CK5 country, we don't flame newbies......We were all there once. Welcome aboard!!!!![​IMG]
    <font color=blue> NEVER FORGET, NEVER FORGIVE, NEVER SURRENDER<font color=blue>
  7. jekbrown
    May 19, 2001
    45,032
    369
    Vancouver, WA, USA
  8. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    Can you use brakeclean with a auburn posi? I was wondering if it would hurt the clutch packs. Thanks
  9. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    If indoubt spay the housing(carrier), not the loaded case(Auburn Possi).
    FYI, Auburn does reccomend Dyno oil only, do not use Synthic oil(moble 1) !
  10. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    The guy at the shop that put it in told me to run normal gear oil, and 1 bottle of the GM LSD oil. So thats what I do. I use 80W-90 and 1 7oz (i think) bottle of the GM LSD oil. Thanks for the info Ex.
