Diff oil replacement
Discussion in 'The Garage' started by shaun, Mar 19, 2004.
  1. shaun
    shaun 1/2 ton status
    Apr 22, 2003
    745
    So I got to change my gear oil. But I am not sure if I should use the actual gasket or RTV or both so...........
  2. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    For years now I only use Black RTV to seal my diff covers. I put a rag ontop of the diff then wire wheel the bolt hole surface, then use the rag to make sure no crap got on the diff or in the housing.
    clean the cover too
    Then I run a small bead on both cover & housing. I let it cure up fer a beer or two(about 15min) then squish it together..done deal.
    I try not to put too much on so when it squishes the RTV doens't go everywere.
    Good luck /forums/images/graemlins/peace.gif
  3. NITRO
    NITRO 1/2 ton status
    Jan 9, 2002
    1,057
    Frankfort In
    I'M NAKED
    NITRO
  4. BurbLover
    BurbLover 1/2 ton status
    Jul 31, 2001
    3,060
    SW Missouri
    One thing I found is that if you hit an object hard enough to dent you cover at the flange, you can get a leak if you only use the gasket. By using RTV (I use grey for eveything), it flexes witht he bend and doesn't leak.
    Anyway, just my unsolicited opinion.
  5. bigyellowjimmy
    bigyellowjimmy 1/2 ton status
    Jan 15, 2004
    2,105
    Chandler, AZ
    Thats been my experience as well /forums/images/graemlins/thumb.gif
