Diff Question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Russell, Jan 18, 2005.
  1. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,925
    337
    Fort McMurray, Alberta
    What type of diff is this? 10 bolt or Dana44?
    Is it worth finding a Dana44 if it is a 10 bolt?
  2. ss396
    ss396 Registered Member
    Jan 20, 2004
    29
    Puyallup/Sumner Area WA
    10 Bolt. I think a lot of guys prefer the dana 44, not sure if they are any stronger.
    I will wait until my 10 bolt breaks, then I will have the same decision to make.
  3. Russell
    Jun 23, 2000
    7,925
    337
    Hmm, thats unfortunate... The guy I bought it from told me it was a D44 :P
    Oh well, if it doesn't break, its good enough for now :)
  4. OrangeCrushK10
    OrangeCrushK10 1/2 ton status
    Jan 25, 2003
    1,425
    Square State + Suspension Item
    10-Bolt
    I prefer a D44 because there are more of them, which means cheaper and easier to find parts. The 3/4 ton D44's have 8 lug rotors to match your 1 ton rear. And the older D44's can be modified to run crossover steering.
    All good stuff. :D And that picture is definetly a 10-bolt.
  5. Russell
    Jun 23, 2000
    7,925
    337
    Yeah, she has got a 10.5 14 bolt FF rear, 4.10 gear ratio. I'll run this front diff till I can find a d44, then I'll sell this diff to my buddy and put the D44 under :)
  6. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    puting a 44 under there is really pointless IMO. The strength difference is non existent and the I don't know about your junkyards but I know in mine the 10 bolt is easier to find than a 44. Mine you that the 1/2 shafts are exactly the same as the 3/4 ton ones in the 10 bolt. I have a 10 bolt with 8 lug outers on my 89 burb, if I bust a shaft all I need to do is find a shaft fron an 89 blazer to replace mine(I have the 30 spline front shafts which is another story).
    10 bolts can be modified to run crossover just fine you just need knuckles from an older D44.
  7. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    That is a 10 bolt for sure. I prefer a 10 bolt over a D44 anyday. 10 bolts are newer axles which means the metals in the axleshafts and such has probably had less of its fatigue life used up. Parts are easier to find and cheaper to find because they are newer and alot of people believe the myth about D44 being better axles so they swap in D44's.
    If you swap out a 10 bolt for a D44 with the idea a D44 will do anything better then a 10 bolt you are a victim of the D44 myth too. You can put crossover steering on a 10 bolt no problem. I am about to go jump in my truck with crossover steering and a 10 bolt and drive to work.
    Harley
  8. chasone64
    chasone64 Registered Member
    Dec 15, 2004
    88
    Oregon
    I plan on keeping my 10 bolt, untill I can afford a D60. They are a lot more popular in the J/Y's here also then the D44, and they are cheaper.
  9. Russell
    Jun 23, 2000
    7,925
    337
    Hmm, this makes me feel much better about things... I haven't really got that much experience with 4x4 stuff yet, so I was under the impression that a D44 was a significantly better axle. Now I know that they are just as good, so I am not concerned with it :)
