Diff swap
Discussion in 'The Garage' started by BlitzK5, Oct 21, 2005.
  1. BlitzK5
    BlitzK5 1/2 ton status
    Jul 29, 2005
    288
    Sherwood Park, Alberta, Canada
    If i take everything out of one diff and install it into another will everything be ok including backlash and all that other stuff. I want to swap a set of 2:73 for 3:73's from one 10bolt to another.
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    I doubt it. There are always machining differences between axles.
  3. trailblazr81
    trailblazr81 1/2 ton status
    May 27, 2005
    931
    Hollister, CA
    I would think you'd have to set up everything. Youll have to reinstall the pinion with new crush sleeve, shim it to center, and adjust for backlash and all that good stuff. You can always try n see!!
  4. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Like the chief says!
  5. BlitzK5
    Jul 29, 2005
    288
    Crap. Well I am going to try it anyways and then post a pic on here showing the backlash and hopefully someone who knows how to will tell me if its ok or if it needs to be adjusted. Then if it is does I will bring it to a shop and get it done by someone who know's how. What is the yellow stuff that everyone uses to check if the backlash is correct and where do you spray it?
  6. dyeager535
    26,982
    191
    You probably won't get a good pattern throwing a different carrier in there with existing gears. Randy's ring-pinion says that it's pretty tough to get a good pattern with used gears.
    Not sure the technical name, I've just called it gear marking compound. It's a paint on stuff that I got with my bearing kit.
    You could try a before/after pattern, but in the cases I've done this, either the gears howled or they didn't. Howling=fix the problem.
  7. readymix
    May 30, 2004
    6,706
    26
    You can get a tube of Prussian Blue at most any auto parts store. It is a little harder to usse than the standard gear marking compound though. The pattern is harder to see.
    Try the swap then post up pics and i will tell you what to adjust.
  8. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Do you have the whole other axle assembly ? Why not just swap the whole 9 yards , you can reuse your brakes etc . Just clean it up and replace the seals/bearings on the axle ends .
  9. BlitzK5
    Jul 29, 2005
    288
    No I was going to grab it off the same truck I got the 14 bolt from at the wreckers So i didnt want to buy the whole thing. Beside I have newer ball joint and seals in mine know.
  10. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,996
    134
    If you don't know how to set up gears, you will run into some pretty major problems. Even if you are willing to deal with the noise they will make, they will not survive long and they will probably break while wheeling. Either buy and swap the whole axle or pay someone to do it right.
  11. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    You should be close. Yes, no two housings are the same, but youll still be in in the ball park, and not like you starting from scratch. Mark your caps, keep your shims in the correct places, check the backlash and pattern BEFORE you tear apart the 3.73'd axle.
    Mark the caps on the housing yoru going to use, check the backlash and pattern on the gears yoru going to use. Take it apart and keep the shims in the right side, the pinion has the shim behind the bearing. Check the bearings and races. Put a new seal and crush sleeve, make sure you crush the sleeve and the bearings are seated. Youll need a few tools like a 1/2" gun, decent sized prybars, brass punch, something to install the new seal without damaging it and big hammer.
  12. 1977k5
    May 26, 2003
    9,996
    134
    So you are suggesting that someone who had never set up a rear end crush a crush sleeve and check the pinion bearing preload by hand and feel? I'm sure those pinion bearings will last longer than a week :rolleyes: . You "might" be able to keep the backlash close enough to make it work, and the pinion depth shouldn't change, but the pinon bearing preload really needs to be set right or your pinion bearings will not last.
  13. kgblazerfive
    kgblazerfive keymaster Premium Member GMOTM Winner
    Dec 2, 2004
    10,622
    611
    Hooper, Utah 84315
    I've done it and it worked, if its in the front how much use is it going to get
  14. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Well I never said anythign about crushing the sleeve and checking it by hand, eventhough thats how I do it.
  15. 1977k5
    May 26, 2003
    9,996
    134
    I can get very close by hand as well (though I still use an inch pound torque wrench to check it), but that is because if have done 15 or so. I guess if it is for the front with a 208 (part time) and manual hubs on the front and you don't plan on driving very fast in 4wd, you will probably be ok.
