Differance between a dually and regular D60?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by chvyhs, Nov 20, 2002.
  1. chvyhs
    chvyhs 1/2 ton status
    Feb 12, 2001
    1,469
    Murrieta, California
    What has to be changed on a dually D60 to make it the same as a regular D60. Is it the same backing plate, rotors, calipers, and steering? I was thinking it was just the hubs that were different. /forums/images/graemlins/1zhelp.gif Are the parts available at the local autoparts store?
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Just the hubs are different, the SRW hubs are going for about $300 right now, so bring your wallet! /forums/images/graemlins/thumb.gif </font color>
  3. chvyhs
    Feb 12, 2001
    1,469
    SRW hub? Single rear wheel?
    So I can just change hub and put it back on the same rotor and it will be the same as a regular D60?
  4. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,126
    53
    Powell, Wy
    you can do that or have a machine shop move the wheel mounting surface back down to the same as a SRW. I think Wagoner machine shop charges $250 ??? for that service too.
  5. nvrenuf
    Jan 7, 2002
    13,079
    247
    Mobile, Al.
    You can reuse the dually rotor BUT the holes in the rotor are not the right size and will need to be drilled open to accomodate the correct studs.
  6. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
    i have done this mod here are some pics, wagoner machine did the work
  7. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    rich,
    /forums/images/graemlins/k5.gifif you need help, I can hook you up with a guy who can do the turning for you....
  8. chvyhs
    Feb 12, 2001
    1,469
    Thanks for all the info. I'm just weighing all my options.
    Tony, I might be taking you up.
  9. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    If you didnt want to change the hubs you could always run hummer beadlocks like Mike is on project eyeore.
  10. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
  11. chvyhs
    Feb 12, 2001
    1,469
    I have 2 beadlock rims like that to use if I get the axle.
    Thanks for the ebay link too, I never thought of that.
  12. chvyhs
    Feb 12, 2001
    1,469
    I forgot to ask how would I run the beadlocks on my 14 bolt FF?
  13. zcarczar
    Feb 10, 2002
    2,495
    Get a dually rear end.
  14. bigjbear
    Feb 18, 2000
    13,971
    452
    Marietta GA
    If you're talking about running the humvee bead-locks just running the DRW rear wont help, it isn't any wider. What you need are DRW spacers, or run the rim backward.
  15. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Or keep it narrower in the back.
    Or get a Van 14bFF.
  16. bigjbear
    Feb 18, 2000
    13,971
    452
    Marietta GA
    Nope, the humvee wheels have too much backspacing to just run-even w/ a van housing.
  17. 86K5TrailBlazer
    86K5TrailBlazer 1/2 ton status
    Apr 24, 2001
    436
    Orange,CA
    ive heard of some success flipping them in the rear dont know how the nuts will seat but seems like for ORO rig that you would be fine /forums/images/graemlins/wink.gif I think im just gonna get mine recentered. although i do like the hub protection 7" on a dually front provide. But thats why you get bigger tires /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  18. jackedjimmy
    jackedjimmy 1/2 ton status
    May 18, 2002
    195
    Redmond WA
    you can get te d60 hubs from Dynatrack. I called them and they said something like $280 side for the hub,rotor,studs and races assembled. Not too bad for new stuff.
  19. chvyhs
    Feb 12, 2001
    1,469
    I tried them on backwards once with 36's. They stick out too far. What is this DRW spacer? How far does it space out the wheels and can I instal it on my FF?
    Thanks for all the other input.
