Differance in T cases
Discussion in 'The Garage' started by BNeu, May 9, 2004.
  1. BNeu
    BNeu Registered Member
    Feb 9, 2003
    12
    I was told i have to find a T case that matches my 700R4, How do I tell the differance between the cases if there already out of the truck and just laying in the JunkYard in a trailer. Will there be a differnt serial code/ number on them? I found a 208 but dont know if it will work.
    -Bryan-
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Well you could try and count the input gear splines. The output on a 700R4 has 27 splines, the input on a 208 has either 27 or 32, 27 being the more common of the 2. The 32 spline units go behind TH400s and SM465s. You need to find a Tcase with a 27 spline input. As for codes or anything I can't help you there. I just remember what Tcase came from what trans and such when I have them sitting around.
  3. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    Here's an easy way to point you in the right direction, only look for aluminum cases....A cast iron case never came behind a th700R4. When you find a 208 or 241 chances are that it came from behind a 700 but count the splines to make sure.
    FYI. since you are looking, I would find a 241 instead of a 208 because they have a lower low range, better oiling system, and are slightly stronger.
