difference bettween 3/4 ton and 1 ton 14 bolt?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 88jimmyoungowner, Mar 1, 2002.
  1. 88jimmyoungowner
    88jimmyoungowner 1/2 ton status
    Nov 20, 2001
    425
    georgia-rome
    what is the differece bettween them?
    16, 88 jimmy, kearning, but still need help
  2. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    Shock mounts, spring pads, and I believe the 1-tons had a brake drum of a slightly bigger size. I'm sure some 1-ton'ers will come forward on this.
    <hr></blockquote>
    What do you mean, Where did I get it??...I <font color=blue>BUILT</font color=blue> the <a target="_blank" href=http://mandydyer.tripod.com/55WillysWagon4x4.htm>damn thing</a>!!
  3. 88jimmyoungowner
    Nov 20, 2001
    425
    georgia-rome
    but are they the same strength?
  4. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    I would say so, I have the 3/4 ton model.
    Anyone with a 1-ton 14 wanna help me out here??
    <hr></blockquote>
  5. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    All the internal "strength" parts are all the same as far as I am aware. If you are wanting to swap a 14bff into a K5 then the 3/4 ton makes for an easier swap. If you are towing the 1 ton might be a better choice due to the bigger brakes.
    My Chevy isn't broken, its just out of gas. <a target="_blank" href=http://coloradok5.com/gallery/albuo73>My K5</a>
  6. 86K5TrailBlazer
    86K5TrailBlazer 1/2 ton status
    Apr 24, 2001
    436
    Orange,CA
    Bigger brakes seem to be about it. Mine are huge compared to the 3/4 which are comparable to 1/2 ton brakes. Yeah it works really well.
    <a target="_blank" href=http://www.myk5.com/gallery/>SoCal Big Dawgs</a>
  7. txguy
    txguy 1/2 ton status
    Sep 4, 2001
    114
    Round Rock (Austin) Tx
    Easier swap?
  8. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    55Willy has it right on every count.
    Russ
    85 K30 CUCV, 350 TBI, TH400, 205, D60/C14, 4.56 Locked, 4" lift, 42" tires
    Some day: massive cutting, shorter wb and rear overhang.
  9. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    Yep, easier swap. On 3/4 ton axles you don't have to relocate the spring plates. A 1 ton has to have the spring plates cut off the factory plates, and weld a new set on in the proper positions. You can get the 3/4 ton axle, and bolt it in in place of the 1/2 ton axle. From what I understand you do have to move the shock mounts on the axle, possibly modify the E-brake cable to work, and get a Napa #447 hybrid u-joint. Along with 8 lug wheels.
  10. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Easier because you don't need to mess with spring perches or shock mounts if you use a 3/4 ton.
    Russ
  11. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Hmm, do the shock mounts require moving? I guess I was wrong on that.? I thought the 3/4 was "complete bolt in" to a K5. In this case "complete bolt in" meaning uses common tools and no welding/fab required. Dealing with mismatches in the joint, wheels, and e-brake cables are a given but still considered "bolt in".
    Russ
  12. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    I thought the 3/4 ton shock mounts lined up? I don't know cus I cut mine off before I even swapped it in.
    <hr></blockquote>
  13. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    3/4 ton is a bolt up but the e brake cables might not work. If it is a Burben 3/4 ton it is a direct swap including e brakes. 1 ton has bigger brakes and depending on years the e brake will bolt in but you need to move spring perchs and shock mounts. The total width is the same between the 2.
    See <a target="_blank" href=http://coloradok5.com/gallery/Waynes-Toy>Project Mighty Mouse</a> here.
    <font color=blue>Wayne<font color=blue>
    <font color=blue>Happy Trails<font color=blue>
  14. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    I am not sure if they have to be moved or not. I thought I remember someone saying they did need to be moved. But I don't know. I hope I am wrong. I just got a 3/4 ton 14bff, and that will save me a little $ if I don't have to move them.
  15. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    What year Suburban? On the 80 whatever when they swapped the brake line set up it probably will but on the older style(one line per side, instead of both up the drivers side) I have to modify mine to get the 78 burb 14FF to fit the Blazer.
    <hr></blockquote>
  16. 86K5TrailBlazer
    Apr 24, 2001
    436
    Orange,CA
    not money but lots of grinding. I had to move spring and shock perches/mounts but that only took 3 hours, i was puttin in a rear cv anyway so i would have to cut them off anyway. They were beefy though
  17. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    My problem is I don't have access to a welder to weld in new mounts. Ok, thats a lie, I do have access to a welder, but my buddy can't weld for crap, and I have not learned how yet. So it would end up costing me some $ to get the new mounts in.
  18. morphed86k10
    morphed86k10 1/2 ton status
    Jun 25, 2001
    463
    Reno Nevada
    Comparable to 1/2 ton brakes? Not even close!! The drums on my swapped in 3/4 ton 14 bolt are two inches larger in diameter than the 10 bolt drums that were on there before. They also wider, and just plain a lot bigger!
