difference between 1/2 and 3/4 brake master cylinder?
Discussion in 'The Garage' started by sandracer0004, Jan 28, 2004.
  1. sandracer0004
    sandracer0004 1/2 ton status
    Jun 24, 2003
    108
    San Jose, CA
    whats the difference? should i upgrade the master, and the booster on my half ton,
    i have replaced everything else so far
    3/4 disk calipers, proportion valve, rear disks as well.
  2. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    The booster is the same., the size of the piston is larger on a 3/4, because the wheel cylinders are larger. You should use the 3/4 master cyl.
  3. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    77 K10 w/ 350
    Item#: TSM101521
    Price: $ 17.99
    Attributes: Brake Master Cylinder - Remfd
    # of Line Ports: 2
    Bore Size: 1.12500''
    Line Thread Size: 9/16-18, 1/2-20
    77 K20 w/ 350
    Item#: TSM101534
    Price: $ 21.49
    # of Line Ports: 2
    Line Thread Size: 1/2-20, 9/16-18
    Comments:GM Code JB7 (Power Brakes, 8,400 LB., Tandem Diaphram Booster)
    That is from NAPA.
    Looks like the master's have the same bore but the 3/4-ton has the front/back fittings swapped. It also looks like the 3/4-ton uses a dubble diaphram booster which will make for less peddle effort.
  4. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Petrolia,Ontario,Canada but working in Port Huron,
    Triaged....the M/C bore king! /forums/images/graemlins/grin.gif
  5. sandracer0004
    Jun 24, 2003
    108
    San Jose, CA
    pretty cheap, i mine as well just replace the master for that price. ive already replaced everything else.
  6. dyeager535
    26,979
    If the fittings are swapped, I'm guessing it's an entirely different MC, like a plastic reservoir/aluminum body vs. the cast style. Were they even using the plastic/aluminum MC's back then?
    My '85-88 parts manual lists 3 different MC designs for the C/K/R/V trucks, aluminum, and two cast iron versions.
  7. jwduke
    jwduke 1/2 ton status
    Aug 25, 2001
    721
    Ice Cream Capital of the World, IA.
    No, they were still the steel ones. I don't think they were aluminum/plastic till the new body style came in '81
  8. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    /forums/images/graemlins/tongue.gif
    Sorry for wanting to save someone $20...
    ...just to make them spend $100 on a 3/4-ton booster /forums/images/graemlins/crazy.gif /forums/images/graemlins/waytogo.gif
