Difference between 14 ff open and govlock
Discussion in 'The Garage' started by la_blazer82, Aug 6, 2004.
  1. la_blazer82
    la_blazer82 1/2 ton status
    Apr 12, 2004
    148
    SoCal
    Sorry for the ignorance, new to straight axles. Am thinking of changing out the rear 10 bolt for a 3/4 ton 14 bolt. What's the difference between a opened and a govlocked axle?
  2. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    govlocks are factory installed lockers...notorious for blowing up in 10bolts... stronger in 14 bolts.
  3. la_blazer82
    Apr 12, 2004
    148
    SoCal
    Just asking -- 14 bolt govlocked axle is available and wondering whether it's easy to change out gearing and add a locker (i.e. Detroit). Or whether it costs more than an open 14 bolt
  4. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    I'd look for an open one, it will be easier to swap gears and put a detroit (or whatever locker) in it.
  5. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    I recommend you get one with an open carrier and install a detroit. The Gov lock is ok, but it recquires a lot more wheel spin to activate (approx. 100 rpm). The detroit will lock as soon as one tire slips.
  6. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    I have the 14bff with the factory Gov-Loc, and i wish i had an open carrier to install the Detroit, the Gov-Loc to me doesn't seem to really do much, maybe helps alittle, but not real noticable, it could also need rebuilt too though, but either way, wished i had a little different setup...Get the one with the open carrier. /forums/images/graemlins/waytogo.gif
    OH and the other thing is you can't install a Detroit into a Gov-Loc carrier.
  7. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    To break it down a little more, govlocs have 3 side gears and have a clutch pack. The open 14bolt diffs have 4 side gears. The detroit requires the 4 side gear case to be installed.
    Here's a gov lock diff
    I welded mine solid
