difference between 14bsf & 14bff?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by fixmy59bug, Aug 15, 2006.
  1. fixmy59bug
    fixmy59bug Registered Member
    Feb 28, 2006
    88
    Riverside, Ca
    I hope you all can excuse the barrage of questions I will be unloading here in the next 2 weeks or so, but I am coming from a Vw community and have never really been into domestics or off roaders (especially when you combine the 2). So this is new uncharted territory for me. I recently learned that the rearend in my 73 'Burban is a large GM Corporate 14 bolt. But how can I tell if its a 14bff or 14bsf? Also, what do those terms mean? I am assuming 14 bolt full floater and 14 bolt semi floater? Thanks.
  2. JIMs70K25
    JIMs70K25 1/2 ton status
    Dec 31, 2001
    524
    Chesapeake, VA
    your correct on the full v. semi. The big difference is 1", a 14sf has a 9.5" ring gear and c-clips, the 14ff has a 10.5" ring gear and hub/spindle. 14bsf-axle shaft supports the weight, 14bff-hub/spindle supports weight, axle shaft only turns the tire.
    easiest way to tell is the hub sticking out through the center of the wheel and if your burb still has the stock rearend then it's a 14BFF as the sf did not appear until later.
  3. onetonbb74
    onetonbb74 1/2 ton status
    Dec 1, 2005
    2,083
    Campbell, CA
    ff looks like this[​IMG]
