difference between 208 and 241-c
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bigblue, Jan 8, 2002.
  1. bigblue
    bigblue 1/2 ton status
    Dec 6, 2000
    658
    southern california
    I might buy a NP241-C. I currently have a bad 208. Is it a direct bolt-on.? thanks....
    Surfing is Life...
  2. kpanza
    kpanza 1/2 ton status
    Dec 8, 2000
    1,579
    Lake Forest, Orange County, California
    Jeremy,
    I thought about this a while back...I think it is a bolt on affair except that most of the 241s came with an electronic speedo setup, as opposed to the mechanical speedo of the 208s...maybe someone on here can tell you if there is a certain year that came with the same mechanical speedo setup as your 208??
  3. Russ
    Russ 1/2 ton status
    509
    Summerdale AL
    Keith,
    I thought the electronic speedo deal did not start until 90. I think if Jeremy could find one out of a Blazer/Suburban prior to 90 it should work. I could be wrong, but I figured I was just cursed with the VSS because mine is a 90 model.
    Russ
  4. Brian 89KBlazer
    Brian 89KBlazer 1/2 ton status
    779
    Ontario, Canada
    Yep Keith
    The '89 has the NP241 with mechanical speedo. Mine does anyway [​IMG]
    Brian
    89KBlazer
    Build it Right or Don't build it at all!!
  5. RyansRod
    RyansRod 1/2 ton status
    Jun 13, 2001
    118
    Bay area CA. USA
    Blazers come with 241s stock? Are their driveshafts and cross members the same as say, an 84 K5 like mine?
    Friends don't let friends drive fords
  6. kpanza
    Dec 8, 2000
    1,579
    Great, then I will be looking for an 89 241 soon! My 87 is the 208, and I think the 241 started in 88, so looks like you could get an 88-89 241 and swap in directly in place of the 208...I'm just waiting for my 208 to die (again, I already rebuilt it)...
  7. solowookie
    solowookie 1/2 ton status
    Mar 31, 2001
    3,880
    Wyoming
    I believe they started putting in the electro's i 91 (same year they went from 700r4 to 4L60)... 89 definitely is mechanical, and I believe 90 is also.
    <font color=blue> Jeff - may the force be with you</font color=blue>
    <a target="_blank" href=http://coloradok5.com/gallery/Jeffs-Stuff>link to k5's</a>
  8. Russ
    Russ 1/2 ton status
    509
    Summerdale AL
    My 90 is electronic.
    Russ
  9. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    well answers that... now only question is whether it is all 90's, or if the changed part way through the year?
  10. Russ
    Russ 1/2 ton status
    509
    Summerdale AL
    That's hard to say. I have the GM service manuals for 90, and the C/K manual shows VSS and electronic speedo, but the R/V, G, and P models book shows mechanical speedo and cable.
    Maybe there are both.
    Russ
  11. tori89k5
    tori89k5 1/2 ton status
    Apr 12, 2001
    946
    Pismo Beach, California
    My 90 is electronic too.....
    1990 K5 4" lift, 33's, 3.73's Raptor Tranny and Velvet Rides....
  12. RyansRod
    Jun 13, 2001
    118
    Bay area CA. USA
    What abaout this though, will an NP241-c work with a 4L60E from a Tahoe? I'm thinking about upgrading to TBI and an electronic transmission, thanks
  13. 95 Silverado
    95 Silverado 1/2 ton status
    Nov 9, 2001
    467
    Central PA
    A question? the trucks past '87 used 241's also, but their front driveshaft is on the left side (IFS), the blazers up to '92 were right hand front drive shaft, they both used the NP241, are these cases different or will they interchange.
    '95 Chevy Silverado 1500
    5.7 V8-NV4500- 3.73 rears
    See My Toys: <a target="_blank" href=http://community.webshots.com/user/wdb172454>http://community.webshots.com/user/wdb172454</a>
  14. K5DRAGER
    K5DRAGER 1/2 ton status
    Jul 27, 2001
    1,164
    Momence, IL
    I also have a 90 and its an electronic one. From what I've seen all 90's are. I have yet to see otherwise , but usually when I say that I'm proven wrong.
  15. bigblue
    Dec 6, 2000
    658
    southern california
    OK so it has an electronic speedo. Is that it? I mean it will work with out the speedo right?
    Surfing is Life...
  16. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    I have a 90 that was built in Jan of 90, pretty sure its electronic...I'll check tomorrow...I guess they started making 90's sometime in 89 though...
    90K5
