difference between 2wd and 4wd steering box?
Discussion in 'The Garage' started by Cornfield creations, Oct 30, 2005.
  1. Cornfield creations
    Cornfield creations 1/2 ton status
    Oct 19, 2005
    1,283
    Jasper, Indiana
    Is there a difference between a 2wd and a 4wd steering gearbox. I thought I heard that the 2wd turns quicker? We have a parts 2wd with low miles and I was considering swapping them if it is quicker and tighter.
  2. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    Only difference is the shaft....and the shafts swap back and forth anyways. Careful though, there's a certain year that they switched over to different fittings.
  3. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    With a 2wd steering box the pitman arm moves side to side and the 4wd moves front to back. The sector shaft is different which won't allow you to just swap pitman arms. The 4wd box has a through bolt holding the pitman arm onto the sector shaft whereas a 2wd bos uses a nut and washer to hold it on. You need a 2wd steering box if you're doing crossover steering otherwise the 2wd box won't work unless you install a 4wd sector shaft. I believe the year difference for the fitting change was 1980 and earlier for the flare fitting hose and 1981 and later for the metric O-ring style hose.
  4. Cornfield creations
    Oct 19, 2005
    1,283
    Jasper, Indiana
  5. TravisO
    TravisO 1/2 ton status
    Apr 17, 2003
    143
    Aloha, OR
    Or a 2WD sector shaft installed in a 4WD box.
    Travis
  6. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    The only difference is the sector shaft is splines 360 degrees on the 2wd box , allowing the pitman arm to be clocked where it needs to be for crossover steering .
    On a 4wd box it is only splined on part of the shaft , and has a cutout for a keeper bolt . So it cannot be clocked .
    I have seen a pitman arm cast for a 4wd box that is clocked for crossover . Search its on CK5 .
    The actual range of motion is the same on both boxes , take off both pitman arms and mark a dot on the edge , and turn the input shaft on each box , they will both rotate the same way .
  7. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    yep
    but its also simple to just swap the shafts
    same casting box
    good luck
  8. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    You need to make sure they are both of the same ratio box before you swap shafts as the rack nut and sector shaft are different between standard ratio and variable ratio. Also i'm sure that everyone who has changed just the shaft haven't ran into any troubles YET but the sector shaft does take a wear pattern to the rack nut and after i tore apart several steering box's i would not change just the sector shaft, but that's just me.
  9. destinbeachman
    destinbeachman 1/2 ton status
    Aug 31, 2005
    365
    Florida
    So a drop isn't required when running a crossover/high steer setup?The standard 2WD arm works?
  10. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    Yes, you will need a dropped arm, ORD sells them, i think it is from some Ford IIRC.
  11. destinbeachman
    Aug 31, 2005
    365
    Florida
    Yeah,there's always one more piece neccessary,doesn't matter what kind of project you have going.I'll probably get ORD to just send everything I need at once,from the arms to a rebuilt pump.Thanks for the info.-Allen
